Bug Report 0.62b - OBS Crash on open process
Defiasen
This crash appears to have occured in the 'd:\program files\obs\64bit\obsapi.dll' module.
**** UNHANDLED EXCEPTION: c000001d
Fault address: 000007FEF0362DB0 (d:\program files\obs\64bit\obsapi.dll)
OBS version: Open Broadcaster Software v0.62b
Windows version: 6.1 (Build 7600)
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Crashing thread stack trace:
Stack            EIP              Arg0             Arg1             Arg2             Arg3             Address
000000000029EFE0 000007FEF0362DB0 000000013F720000 1000F70A00000008 00000000005908D0 000000000029F1E0 obsapi.dll!log10f+0x2a0
000000000029F060 000007FEF032972A 000007FEF036E298 1000F70A00000002 00000000005908D0 0000000000590800 obsapi.dll!InitVolumeMeter+0x1a
000000000029F0E0 000000013F74CADB 000007FEF036E298 000007FEF036E298 0000000001FC1000 0000000000000000 obs.exe!OBS::OBS+0x24b
000000000029F490 000000013F747700 0000000000000000 0000000000000001 000000013F720000 0000000000000000 obs.exe!WinMain+0x9d0
000000000029FA30 000000013F7BCB50 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!__tmainCRTStartup+0x148
000000000029FA70 00000000776EF34D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x776ef34d
000000000029FAA0 0000000077922CA1 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x77922ca1
A minidump was saved to C:\Users\*****\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-04-23_6.dmp.
List of loaded modules:
Base Address                      Module
000000013F720000-000000013F875000 D:\Program Files\OBS\64bit\OBS.exe
00000000778F0000-0000000077A9C000 C:\Windows\SYSTEM32\ntdll.dll
00000000776D0000-00000000777EF000 C:\Windows\system32\kernel32.dll
000007FEFD9E0000-000007FEFDA4C000 C:\Windows\system32\KERNELBASE.dll
000007FEFC7B0000-000007FEFC7B9000 C:\Windows\system32\AVRT.dll
000007FEFF4B0000-000007FEFF4CF000 C:\Windows\SYSTEM32\sechost.dll
000007FEFF1B0000-000007FEFF24F000 C:\Windows\system32\msvcrt.dll
000007FEFDC70000-000007FEFDD9E000 C:\Windows\system32\RPCRT4.dll
000007FEFBBB0000-000007FEFBBC8000 C:\Windows\system32\dwmapi.dll
000007FEFDDB0000-000007FEFDE17000 C:\Windows\system32\GDI32.dll
00000000777F0000-00000000778EA000 C:\Windows\system32\USER32.dll
000007FEFDDA0000-000007FEFDDAE000 C:\Windows\system32\LPK.dll
000007FEFFB30000-000007FEFFBFA000 C:\Windows\system32\USP10.dll
000007FEF7A00000-000007FEF7AA7000 C:\Windows\system32\dxgi.dll
000007FEFF5E0000-000007FEFF6BB000 C:\Windows\system32\ADVAPI32.dll
000007FEFC960000-000007FEFC96C000 C:\Windows\system32\VERSION.dll
000007FEF9910000-000007FEF9944000 C:\Windows\system32\d3d10_1.dll
000007FEF7D30000-000007FEF7D85000 C:\Windows\system32\d3d10_1core.dll
0000000077AC0000-0000000077AC7000 C:\Windows\system32\PSAPI.DLL
000007FEF09C0000-000007FEF0A3F000 C:\Windows\system32\d3dx10_43.dll
000007FEFF6C0000-000007FEFF8C2000 C:\Windows\system32\ole32.dll
000007FEFF460000-000007FEFF4AD000 C:\Windows\system32\WS2_32.dll
000007FEFF550000-000007FEFF558000 C:\Windows\system32\NSI.dll
000007FEFB300000-000007FEFB327000 C:\Windows\system32\IPHLPAPI.DLL
000007FEFB2C0000-000007FEFB2CB000 C:\Windows\system32\WINNSI.DLL
000007FEFB830000-000007FEFB86B000 C:\Windows\system32\WINMM.dll
000007FEF0310000-000007FEF0540000 D:\Program Files\OBS\64bit\OBSApi.dll
000007FEFB2B0000-000007FEFB2BC000 C:\Windows\system32\XINPUT9_1_0.dll
000007FEFF280000-000007FEFF457000 C:\Windows\system32\SETUPAPI.dll
000007FEFDA50000-000007FEFDA86000 C:\Windows\system32\CFGMGR32.dll
000007FEFDEE0000-000007FEFDFB7000 C:\Windows\system32\OLEAUT32.dll
000007FEFDA90000-000007FEFDAAA000 C:\Windows\system32\DEVOBJ.dll
000007FEFE420000-000007FEFF1A7000 C:\Windows\system32\SHELL32.dll
000007FEFF560000-000007FEFF5D1000 C:\Windows\system32\SHLWAPI.dll
000007FEFBD60000-000007FEFBF76000 C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.17007_none_2b47185a719d6182\gdiplus.dll
000007FEF97D0000-000007FEF983E000 C:\Windows\system32\WINHTTP.dll
000007FEF9760000-000007FEF97C4000 C:\Windows\system32\webio.dll
0000000066560000-000000006678B000 D:\Program Files\OBS\64bit\libx264-140.dll
000007FEFBF80000-000007FEFBFD6000 C:\Windows\system32\UxTheme.dll
000007FEFD6E0000-000007FEFD737000 C:\Windows\system32\apphelp.dll
000007FEF0C00000-000007FEF0C51000 C:\Windows\AppPatch\AppPatch64\AcGenral.DLL
000007FEFD6B0000-000007FEFD6D5000 C:\Windows\system32\SspiCli.dll
0000000072520000-0000000072523000 C:\Windows\system32\sfc.dll
000007FEF94B0000-000007FEF94C0000 C:\Windows\system32\sfc_os.DLL
000007FEFCB60000-000007FEFCB7E000 C:\Windows\system32\USERENV.dll
000007FEFD850000-000007FEFD85F000 C:\Windows\system32\profapi.dll
000007FEF7E80000-000007FEF7E98000 C:\Windows\system32\MPR.dll
000007FEFF250000-000007FEFF27E000 C:\Windows\system32\IMM32.DLL
000007FEFDFC0000-000007FEFE0C9000 C:\Windows\system32\MSCTF.dll
000007FEFD810000-000007FEFD842000 C:\Windows\system32\nvinitx.dll
000007FEFD740000-000007FEFD74F000 C:\Windows\system32\CRYPTBASE.dll
000007FEFC030000-000007FEFC224000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_fa62ad231704eab7\Comctl32.dll
000007FEF0850000-000007FEF09C0000 D:\Program Files\OBS\64bit\DBGHELP.DLL
Upon clicking the process on my taskbar, I can no longer open OBS. I click, it instantly crashes. I've moved the custom plugins out of the folder too.
  • OBSCrashDump2014-04-23_6.dmp
R1CH
"Limit CPUID" mis-reports what features your CPU supports. You're getting an "illegal instruction" crash so it might be trying to use something your CPU doesn't support.
Defiasen
The feature, "Limit CPUID Maximum" is disabled in my BIOS.
R1CH
Strange. Your crash indicates an AVX instruction generated the exception, but the i7-4770K should definitely support AVX.
R1CH
Keep using the 32 bit OBS. There's no real reason to use 64 bit, it's less compatible with plugins and devices.
Defiasen
Oh. I was told a while back (Year?) to use the 64bit version since it ran better overall with my system. I guess I can try and fix the 32bit plugins and roll with it.
Now Im getting this with one of my plugins (Desert IRC)
It's probably just the plugin, but I wasn't having this issue on an older version so the update might have changed something it uses.
Lain
Lain
We may have written a workaround for this. We're probably going to make a hotfix soon if we can confirm.
