Bug Report 0.7.2 Crash when scaling
kalmarin
Happens only in D3D mode. I have the latest vc2013 runtimes, drivers etc.
Can't copy crash log. I can interact with the crash reporter (scroll/select etc.), but it crashes immediately when I click 'copy crash log' or Ctrl+C.
Video: http://youtu.be/GVplla6WC_s
1680x1050(native) - crash
to 1344x840 - works
to 1260x787 - crash
to 1120x700 (default setting) - works
to 1008x630 - crash
to 960x600 - works
to 840x525 - crash
to 746x466 - crash
to 672x420 - works
Have to delete settings folder for it to not crash on start up.
  • 2015-01-07 18-29-24.txt
  • 2015-01-07 18-30-14.txt
  • 2015-01-07 18-31-46.txt
  • 2015-01-07 18-32-30.txt
  • 2015-01-07 18-38-15.txt
kalmarin
Oh.. sorry about that, I should have checked the forums more thoroughly before posting. Feel free to delete this thread.
Lain
Lain
Crash with specific scaled resolutions is a known issue, if you need to reset or manually edit your settings or anything, type in %appdata%/obs-studio/basic in to a windows run box, and then edit or delete the basic.ini file.
