Question / Help 120 fps recording are actually 60 fps?
ULTIM4T0
I was about to do some slow motion video of warframe and I noticed, that even though I set the recording to 120 fps and having solid 120 fps in game, the recorded video does not seem to have 120 fps.
Example video:
https://www.youtube.com/watch?v=08TZDrLUPxM&feature=youtu.be
You can see the current frames below the video preview. You can see, that only every second frame is actually changing wich should be 60 fps then.
I showed the proberties of the source file (120 fps) and recorded the rivatuner statistics server overlay too.
fps: pretty solid 120
gpu usage: ~60%
cpu usage: ~40%
recorded on an SSD
Log file has been attached.
So why is that? I recorded with MSI Afterbruner before and was able to actually record 120 fps videos but all of a sudden Afterburner reduces my GPU usage to 50% or less as soon as I'm recording, wich results in fps losses in game. So I recently switched to OBS, therefore I dont't have much experience with it.
Thanks in advance for any help.
EDIT:
I found out that this is a Warframe specific problem, other games can be recorded in 120 fps just fine (eg. slay the spire).
  • 2018-11-29 17-06-48.txt
