3090 Higher Usage than my 980Ti
DarienJMM
Hi,
I just got a 3090 and put it in my machine, I have updated all drivers for windows, GPU & OBS. My issues is that when I was using my 980Ti for livestreaming at 1664x936 downscaled from a base canvas of 2560x1440 it would only use 20% of my GPU (this is when streaming and not streaming, it didn't effect its usage unless I was recording for some reason). However I have tried test streaming with my 3090 (no settings have changed) and all of a sudden it is using 60%>, does anyone know why this might be & how to fix it?
I have provided 2 log files, one from my livestream a few days ago when I had my 980Ti installed and one from today with my 3090 installed.
**Update**
I get 60%> GPU usage if I record or if I use the Replay Buffer, this isn't a normal GPU usage for a 3090 is it? I do still get an idle 20% GPU usage on my 3090 same as my 980Ti. Anyway of knowing why this is?
  • 2020-12-05 14-36-07.txt
  • 2020-12-07 19-06-01.txt
R1CH
Are you sure your 3090 is running at max clock speed during your monitoring? GPU usage is relative - 60% of 200 MHz idle clocks is less than 20% of 1400 MHz full clocks.
DarienJMM
It is using around about 60% while no games or programs are open whenever I have a replay buffer or recording active, it is sitting around 17% right now idle and 20% streaming. I have my bitrate set from 20,000 down to 8,000 for my recording (20,000 was recording fine on my 980Ti & changing the bitrate didn't effect the usage, it was still 60%>). And not sure about Max Clock Speed, if thats the same as the Task Manager usage then its around 60% (which imo is very high for a blank screen with a small webcam active and 2 overlays. When compared to what the usage on my 980Ti)
DarienJMM
Another note:
When ONLY Streaming it is 18%.
When ONLY Replay Buffering it is 25%
When Replay Buffering + Streaming it is 50% (I downscaled my recording from 1440p base canvas to 1080p, which is why it isn't 60%> now.)
Streaming + Replay + Recording is the same as just Streaming + Replay, same goes for just recording.
DarienJMM
These are 2 more test I have done while playing video games, one was streaming without the Replay and the other was with the Replay buffer.
  • Replay Bufffer.txt
  • Streaming no Replay.txt
