Bug Report 4k Extreme 10 bit gets set back to 8 bit
ciscoiptech
I have the deck-link 4k extreme and when I set my video input to HD 1080p 60 - 10 bit 4:2:2 YUV in either the global source section or the sources section when I either hit preview stream or if I go live the software changes it back to HD 1080p 60 - 8 bit 4:2:2 YUV.
I am using the latest test build # 6 see the attached jpegs I want to use 10 bit and have it stay like that. For giggles I tested it with x split and x split leaves it at 10 bit. This is not logged in the LOG it just changes it back to 8 bit no indication in the log that it has done so.
I am also still having the issue with OBS crashing and freezing when switching back in fourth between scenes described here viewtopic.php?f=6&t=2208&p=12646#p12646
And it seems as though the frames that I observer in the preview window to not always stay @ 60 FPS.
My streaming PC http://www.youtube.com/watch?v=eZusJ7oYtd4&hd=1
Intel Core i7-3930K Hexa-Core Processor 3.2 Ghz 12 MB Cache @ 4.7 GHZ
Blackmagic Design DeckLink 4K Extreme
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ16GX3M2A1600C10)
Corsair Enthusiast Series 650-Watt 80 Plus Bronze Certified Power Supply Compatible with Core i3, i5, i7 and platforms - TX650
EVGA GeForce GT 610 1024MB GDDR3, DVI, DVI, HDMI, Graphics Card Graphics Cards (01G-P3-2616-KR) Graphics Cards 01G-P3-2616-KR
http://www.twitch.tv/ciscoiptech
Thanks,
ciscoiptech
R1CH
There's not much point in having it at 10 bit, x264 colorspace is 8 bit 4:2:0 so it will just get converted anyway, xsplit is the same. I have no problems with my Decklink device freezing or dropping frames, did you add it as a global source yet?
ciscoiptech
Rich Xsplit does not change back to 8bit and there is a huge color difference from 8 to 10. Will we be able to edit the color of the capture card in the future?
Thanks,
Justin
R1CH
OBS has no control over the user settings of the capture card, it's not like it is purposefully setting it to 8 bit. It's just that 8 bit is likely the only compatible filter path since 10 bit requires a color space that OBS does not support.
ciscoiptech
OK I ask because xsplit does not operate this way and does allow the 10 bit color space. I am comparing and contrasting between the two software platforms. And in xsplit I can right click on the deck-link and change contrast brightness etc via the color tab also on the aver-media while obs does not have these options.
Thanks,
Justin
R1CH
Changing the contrast and brightness is unrelated to the color space, unless you are doing 4:4:4 local recording it is unlikely you will see any difference between 8 and 10 bit.
ciscoiptech
10-4 I get that they are unrelated just talking about two different things now :-) I can definitely see the difference between 8 and 10 bit color. I would also like the option to change the color on the capture card, but this is just a wish just trying to let you know what would be preferred.
Justin
