Bug Report 64 Bit OBS Not working with displays, but 32 bit works fine.
halldk
The 64bit version of the software will recognize, but not allow for recording/display of my mointors. Will work with game capture, but display captrue will not. 32 bit version, however, works just fine. Not sure why. Attaching logs.
  • 2018-06-09 19-41-30.txt
  • 2018-06-09 20-05-18.txt
  • 2018-06-09 20-06-07.txt
  • 2018-06-09 20-06-43.txt
halldk
This did help, but not in the way it was supposed to. I run a AMD ROG Desktop. With the Nvidia Graphics Card, it will not capture anything. If I go into the 3D settings, and have it use the integrated graphics, then it works fine. So, kind of the opposite of what you sent me. But hey, i found a solution, so thank you!
As an aside, I cannot get my mic to record via OBS, on either 32 or 64 bit version, and this is with both of the Nvidia settings I've tried out. It works fine, I show input on everything else, but as soon as it get into OBS, it won't take the audio. No idea why. Attaching logs again, hope to find an answer. I did see that this was a work in progress in the issues pages, from the one you sent me, just seeing if anyone might have a fix.
Thanks for the lead @Harold
Edit:
Got the audio to work, it was a setting I'd misplaced in Windows. Everything seems to be working alright now! Thanks for the help!!!!
  • 2018-06-14 16-36-19.txt
  • 2018-06-14 16-35-20.txt
  • 2018-06-14 16-38-23.txt
  • 2018-06-14 16-39-00.txt
  • 2018-06-14 16-40-09.txt
  • 2018-06-14 16-46-14.txt
