a lil pixelated and dunno what to do
mucks
okay, so im trying make my streams look decent and without some of the pixels innit. i switched between cpu encoder and gpu encoder to see if its any good, but cant really tell the difference. im struggling with the settings of it and still have no clue what to do with it to make it look better. i attached the log under this post for yall to check it out. thanks
  • 2023-10-02 20-05-34.txt
sandrix
AMD HW H.264
Bitrate Control: CBR
Bitrate: Twitch 6000 (new streamer) 8000 kbps (Affiliate/Partner), Kick 9000 kbps, YouTube from 12500 to 25000 kbps
Key frame interval: 2 s
Preset: Quality
Profile: high
For RX 6000 and 7000 series, enter Max. number of B-frames: 1 - shooters, 2 - non-dynamic content
AMF/FFmpeg parameters: HighMotionQualityBoostEnable=true
Output Resolution: Shooters 1536x864/1600x900/1664x936 other 1920x1080
mucks
AMD HW H.264
Preset: Quality
Profile: high
thank you for the recommendations; i tried it out, but still cant tell the difference imo so here's my second log.
  • 2023-10-03 11-31-35.txt
sandrix
What did you expect from Radeon? They consistently provide terrible quality for the H264 codec.
Try using x264, there are no other options. Or sell Radeon and buy Nvidia.
For x264, use these additional parameters to reduce CPU load
ref=2 no-mixed-refs=0 trellis=1 bframes=0 rc_lookahead=30 scenecut=20 aq-strength=1.5 weightp=2
Using x264 will provide higher quality and less blockiness, but will negatively affect gaming performance. It all depends on the game's CPU requirements.
mucks
sweet, but with analyzer, it says "0.8% Rendering Lag", which it also says the gpu is overloading. should i be worried about it? will it affect the quality? here's me new log info with the settings you recommended with the x264. i also tend to stream at 720p60 on twitch.
  • 2023-10-03 15-26-58.txt
sandrix
Info 0.8% Rendering Lag
Your GPU is maxed out and OBS can't render scenes fast enough. Running a game without vertical sync or a frame rate limiter will frequently cause performance issues with OBS because your GPU will be maxed out. OBS requires a little GPU to render your scene.
Enable Vsync or set a reasonable frame rate limit that your GPU can handle without hitting 100% usage.
If that's not enough you may also need to turn down some of the video quality options in the game. If you are experiencing issues in general while using OBS, your GPU may be overloaded for the settings you are trying to use.
Please check our guide for ideas why this may be happening, and steps you can take to correct it: GPU Overload Issues.
