Advanced Output Timer
Advanced Output Timer 1.1.0
markjay
markjay submitted a new resource:
Advanced Output Timer - A revised output timer that fixes a design flaw in the original and adds a start recording timer
The original output timer has a design flaw where if you set the output timer for your stream and then realize you want to change the timer, if you click stop, your stream stops. The same issue is present for the recording stop timer. This modified version fixes that. Additionally, it adds a start recording timer which is useful if you go live ahead of your actual stream time to capture viewers and don't want to accidentally forget to hit record at the actual starting time.
skipprnim
hello @markjay just so you know for the macOS users, they don't have to go into System Settings to change the Security and Privacy settings. All Mac users need to do is right-click (or control-left-click) on the package and select Open and they will go straight to the dialogue box asking if they want to Open it or Cancel.
This way is better because it happens for just this one install and they don't have to lower their entire system settings to install unsigned OBS plug-ins. ~Cheers.
