Zoid14
Stream crashes while using Amd's encoder on obs 30-60 minutes into the stream whereas while using x264 I haven't faced any problems with the encoder overloading. But while using H264 even if i follow the prescribed procedures to reduce output res and frame values it still crashes while streaming and after installing the new amd drivers still hasnt fixed the issue. This is all while trying to stream valorant which isnt a demanding game of any sort and i have a double monitor setup the main monitor is 144hz and the other is 60hz.
Pc specs:
GPU: Amd rx 5700xt
Cpu: ryzen 5 3600
  • 2020-11-08 19-01-12.txt
