Gosh
Hello everyone,
i sadly have the following problem, no matter what i try the bitrate of the output file is only a fraction of what it should be and so the video quality is abysmal.
Here are more details:
After reading the log with debug mode on, i have found several errors regarding the initialization of the AMF plug-in (line 58 and beyond) such as
Unable to set converter transfer characteristic, error AMF_NOT_FOUND
*****Encoding Core disabled!
I have already tried to reinstall the AMD drivers (after clean-up), OBS Studio (with user settings), updated Windows and System drivers.
Interestingly enough there are no problems with the AMD Adrenalin Recordings, so it should not be an error caused by a faulty GPU.
My suspicion is that AMF does not fully support the 6000 series GPU's, but i have seen others use OBS to record with theirs so that may not be it.
I would be very grateful if you could help me out and solve this problem
Thanks for reading, have a great day!
  • 2021-06-13 13-12-49.txt
