An encoder error occurred while recording.
Juifa06
It appears there is no one watching the previous thread for "Encoder errors" anymore, so I took the liberty to start another one. I just downloaded OBS as per recommendations from a friend, however, the very first time I tried running it, I got the error message below. Log ======> https://obsproject.com/logs/uarXuUsiqeuzM-ao
Any pointers will be greatly appreciated. Thanks!
Juifa06
Quick update,
I run a 3 monitor display for my system currently
So, I ran the analyzer tool after running the log file and it did give me some recommendations
The results were as follows
I did go ahead and follow the recommendation for the GPU
I did go ahead and turn off the integrated GPU (as an admin) and ran it on my dedicated GPU. Logs =======> https://larta.org/idea/5-types-of-investors/.
It worked!
NOTE!! by disabling the integrated GPU, you are likely to lose the display of the 2nd+ monitor(s). Also I realized the recording quality was lagging and scratchy.
MY QUESTION
How do I get OBS to work run on double/triple monitor with decent quality output ?
Thanks!!
