Bug Report Apparently OBS crashed on me and now can't verify my stream key
So I was streaming fine. Suddenly I dropped frames for no reason. Then not long after that OBS crashed. So I restarted OBS and tried to restart the stream just for it to tell me my stream key was wrong. I went to Twitch and copy and pasted it again and saved it then tried again. Same result. Finally I had Twitch reset my stream key and tried a 3rd time. Still couldn't verify my stream key. Here are all my logs from today.
  • 2015-04-17 12-31-31.txt
  • 2015-04-17 10-26-44.txt
  • 2015-04-17 06-27-06.txt
So now using this version of OBS 0.9.1 I was able to use my stream key to connect to every server but the one closest to me. Now I feel it may just be an issue from Twitch's end. Too bad the support they provide is garbage.
