Question / Help Audio decoding issue
MrLuvvaLuvva
I have streamed with my PS3 in the past, however tonight OBS was capturing the video, but no audio, the log file shows that there is a "channel element 2.2 is not allocated"
Any ideas on how to capture my sound again?
EDIT: I am using a Hauppauge Rocket to stream
EDIT 2: OBS broadcasts my PS4 sound perfectly (HDMI) it is just my PS3 that I can't hear (connected through component to avoid HDCP)
  • PS3 no sound.txt
  • PS4 with sound.txt
Lain
Lain
It's probably that the device is set to a different codec than obs expects, you might be able to change the codec the device is using in their software, and I might be able to make a way to detect it, but for the time being there's not too much that can be done about it.
