Question / Help Audio Echo
Rmont9613
As my title suggest's my viewers hear my voice twice, an echo. To start off I am not listening to my stream, already made that dumb mistake =P. Skype, etc does not echo. Here is my log.
  • log.txt
paibox
heros in an halfshel
In the settings for your webcam, you have your audio device set to your microphone. Change this setting to "Disable" instead, since you already have your microphone specified in the general OBS settings.
Rmont9613
Are you referring to the properties for the video capture device in the sources for my scene? Referring to when you said "In the settings for your webcam, you have your audio device set to your microphone. Change this setting to "Disable" instead". Now when I click to change the properties my OBS crashes. And when I delete the source to try making a new one to get around going into the properties it still crashes.
