Audio Output Capture - Unable to capture Focusrite Scarlett 18i20 2ndG Outputs
mhjn
Hi everyone,
I would like to stream a live band video. I have a camera connected via AVerMedia (works fine) + audio signals (musical instruments and microphones) through Focusrite Scarlett 18i20, mixing the music via Pro Tools 2020. In Pro Tools my playback engine is Scarlett. I need to capture the audio output from Scarlett, but OBS doesn't show any option for Audio Output Capture. It only sees the inputs, I am able to use inputs 1 & 2 (Audio Input Capture). Oh and I'm on a MacBook.
I really need to capture the Scarlett Audio outputs.
Please help!
Thanks,
Martin
Dmd210
Download Blackhole Audio App. https://existential.audio/blackhole/ it’s free. Setup a multi output device include your interface and blackhole app. Then on your daw set output to blackhole and in obs select blackhole as your capture. There’s an install guide on the apps website
