Question / Help Audio pops/glitches while recording
D
Deleted member 249525
So, I've been recording some Geometry Dash lately, and I've noticed that the audio pops and glitches at an extreme scale. It's extremely unbearable and I want it to stop. I've messed around with settings, looking at other forums, running OBS as admin, etc. It also appears as if the bass in the recording is amplified by a lot. Here are some screenshots of my settings:
Log file:
22:57:11.777: CoInitializeEx succeeded: 0x00000001
22:57:11.777: CPU Name: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
22:57:11.777: CPU Speed: 3912MHz
22:57:11.777: Physical Cores: 2, Logical Cores: 4
22:57:11.777: Physical Memory: 8100MB Total, 3090MB Free
22:57:11.777: Windows Version: 10.0 Build 18362 (release: 1903; revision: 836; 64-bit)
22:57:11.777: Running as administrator: true
22:57:11.778: Aero is Enabled (Aero is always on for windows 8 and above)
22:57:11.778: Windows 10 Gaming Features:
22:57:11.778:     Game Bar: Off
22:57:11.778:     Game DVR: Off
22:57:11.778:     Game DVR Background Recording: Off
22:57:11.778:     Game Mode: Off
22:57:11.781: Sec. Software Status:
22:57:11.785:     Windows Defender Antivirus: enabled (AV)
22:57:11.785:     Windows Firewall: disabled (FW)
22:57:11.787: Current Date/Time: 2020-05-22, 22:57:11
22:57:11.787: Browser Hardware Acceleration: true
22:57:11.787: Portable mode: false
22:57:12.457: OBS 25.0.8 (64-bit, windows)
22:57:12.457: ---------------------------------
22:57:12.479: ---------------------------------
22:57:12.479: audio settings reset:
22:57:12.479:     samples per sec: 48000
22:57:12.479:     speakers:        1
22:57:12.481: ---------------------------------
22:57:12.481: Initializing D3D11...
22:57:12.481: Available Video Adapters:
22:57:12.483:     Adapter 0: Intel(R) HD Graphics 630
22:57:12.483:       Dedicated VRAM: 134217728
22:57:12.483:       Shared VRAM:    4246806528
22:57:12.483:       PCI ID:         8086:5912
22:57:12.484:       Driver Version: 26.20.100.7263
22:57:12.484:       output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=59, name=2279WH
22:57:12.487: Loading up D3D11 on adapter Intel(R) HD Graphics 630 (0)
22:57:12.523: D3D11 loaded successfully, feature level used: b000
22:57:12.523: DXGI increase maximum frame latency success
22:57:13.292: ---------------------------------
22:57:13.292: video settings reset:
22:57:13.292:     base resolution:   1920x1080
22:57:13.292:     output resolution: 1920x1080
22:57:13.292:     downscale filter:  Lanczos
22:57:13.292:     fps:               60/1
22:57:13.292:     format:            NV12
22:57:13.292:     YUV mode:          709/Full
22:57:13.292: NV12 texture support not available
22:57:13.293: Audio monitoring device:
22:57:13.293:     name: Default
22:57:13.293:     id: default
22:57:13.293: ---------------------------------
22:57:13.307: [CoreAudio encoder]: Adding CoreAudio AAC encoder
22:57:13.308: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
22:57:13.366: [AMF] Unable to load 'amfrt64.dll', error code 126.
22:57:13.369: [AMF] AMF Test failed due to one or more errors.
22:57:13.369: Failed to initialize module 'enc-amf.dll'
22:57:14.402: Failed to initialize module 'logi_obs_plugin_x64.dll'
22:57:14.404: [obs-browser]: Version 2.8.6
22:57:14.441: Couldn't find VLC installation, VLC video source disabled
22:57:14.451: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
22:57:14.456: No blackmagic support
22:57:14.486: ---------------------------------
22:57:14.486:   Loaded Modules:
22:57:14.486:     win-wasapi.dll
22:57:14.486:     win-mf.dll
22:57:14.486:     win-dshow.dll
22:57:14.487:     win-decklink.dll
22:57:14.487:     win-capture.dll
22:57:14.487:     vlc-video.dll
22:57:14.487:     text-freetype2.dll
22:57:14.487:     rtmp-services.dll
22:57:14.487:     obs-x264.dll
22:57:14.487:     obs-vst.dll
22:57:14.487:     obs-transitions.dll
22:57:14.487:     obs-text.dll
22:57:14.487:     obs-qsv11.dll
22:57:14.487:     obs-outputs.dll
22:57:14.487:     obs-filters.dll
22:57:14.487:     obs-ffmpeg.dll
22:57:14.487:     obs-browser.dll
22:57:14.487:     logi_obs_plugin_x64.dll
22:57:14.487:     image-source.dll
22:57:14.487:     frontend-tools.dll
22:57:14.487:     enc-amf.dll
22:57:14.487:     decklink-ouput-ui.dll
22:57:14.487:     coreaudio-encoder.dll
22:57:14.487: ---------------------------------
22:57:14.487: ==== Startup complete ===============================================
22:57:14.552: All scene data cleared
22:57:14.552: ------------------------------------------------
22:57:14.688: WASAPI: Device 'Speakers / Headphones (Realtek Audio)' [44100 Hz] initialized
22:57:14.688: [Loaded global audio device]: 'Desktop Audio'
22:57:14.692: [window-capture: 'Geometry Dash'] update settings:
22:57:14.692:     executable: GeometryDash.exe
22:57:14.701: Failed to open file 'C:/Users/syndi/Downloads/maxresdefault (1).jpg': No such file or directory
22:57:14.701: gs_image_file_init_internal: Failed to load file 'C:/Users/syndi/Downloads/maxresdefault (1).jpg'
22:57:14.701: [image_source: 'Static'] failed to load texture 'C:/Users/syndi/Downloads/maxresdefault (1).jpg'
22:57:14.703: Failed to open file 'C:/Users/syndi/Downloads/NTSC-color-bars.jpg': No such file or directory
22:57:14.703: gs_image_file_init_internal: Failed to load file 'C:/Users/syndi/Downloads/NTSC-color-bars.jpg'
22:57:14.703: [image_source: 'Censor'] failed to load texture 'C:/Users/syndi/Downloads/NTSC-color-bars.jpg'
22:57:14.718: Failed to open file 'C:/Users/syndi/Pictures/Other crap/sg_Deltarune_Hero (1).png': No such file or directory
22:57:14.718: gs_image_file_init_internal: Failed to load file 'C:/Users/syndi/Pictures/Other crap/sg_Deltarune_Hero (1).png'
22:57:14.718: [image_source: 'Deltarune Background'] failed to load texture 'C:/Users/syndi/Pictures/Other crap/sg_Deltarune_Hero (1).png'
22:57:14.720: [window-capture: 'LiveSplit'] update settings:
22:57:14.720:     executable: LiveSplit.exe
22:57:15.423: [window-capture: 'Window Capture 2'] update settings:
22:57:15.423:     executable: GeometryDash.exe
22:57:15.425: [window-capture: 'Fallout Shelter'] update settings:
22:57:15.425:     executable: FalloutShelter.exe
22:57:15.428: [window-capture: 'Google Chrome'] update settings:
22:57:15.428:     executable: chrome.exe
22:57:15.442: Switched to scene 'Scene'
22:57:15.452: ------------------------------------------------
22:57:15.452: Loaded scenes:
22:57:15.452: - scene 'Scene':
22:57:15.452:     - source: 'Display Capture' (monitor_capture)
22:57:15.452:     - source: 'Fallout Shelter' (window_capture)
22:57:15.452:     - source: 'LiveSplit' (window_capture)
22:57:15.452:         - filter: 'Chroma Key' (chroma_key_filter)
22:57:15.453:     - source: 'Geometry Dash' (window_capture)
22:57:15.453: - scene 'Black Fade':
22:57:15.453: - scene 'White Screen':
22:57:15.453:     - source: 'White Source' (color_source)
22:57:15.453: - scene 'Censored Screen':
22:57:15.453:     - source: 'Censor' (image_source)
22:57:15.453:     - source: 'Static' (image_source)
22:57:15.453: - scene 'Games':
22:57:15.453:     - source: 'Deltarune Background' (image_source)
22:57:15.453:     - source: 'LiveSplit' (window_capture)
22:57:15.453:         - filter: 'Chroma Key' (chroma_key_filter)
22:57:15.453:     - source: 'Window Capture 2' (window_capture)
22:57:15.453: - scene 'Speedrunning':
22:57:15.453:     - source: 'Game Capture Speedrun TY' (game_capture)
22:57:15.453: - scene 'One Chance Speedrun':
22:57:15.453:     - source: 'Google Chrome' (window_capture)
22:57:15.453: ------------------------------------------------
