ItWasntZak
I have uploaded multiple log files, the ones from "2018-11-6" I'm not sure which one is for the "replay_recording" file but the problem has been ongoing so both logs should help. The log file from "2018-11-7" goes with "update_test" file, and is from after I updated OBS while trying to solve this problem.
After recording game play, I noticed that when I brought the video file into Premier Pro the audio wouldn't make any noise and loaded no wave form for it. I was going to solve the problem by rerecording the game from the replay. I was then going to take the audio file from that recording and put it over the other video file. The newly recorded file also had the same audio issue when bringing it into Premier Pro. I then opened these files by themselves in Windows Media Player and the audio was there and working just fine, I then watched the files with the "Video" program on Windows 8.1 and no audio this time. I also dragged the files on to a blank Google Chrome tabs and the video would play but again no audio. I even loaded the files into Ableton Live 9 to see if I could export just the audio and add it to my video, however Ableton would play the video file but wouldn't play the audio or load a wave form for it. The fact that WMP will play the audio with the video but nothing else will makes me think this is a codec issue. I downloaded a video converter that also allows you to choose a audio codec and I tried to reformat it and this did not solve the problem. I checked and OBS had an update, I updated to the most recent version. After updating I recorded another video and the problem is still happening. I'm not sure if it's an issue with my OBS, my computer, or what.
Please send help!
I am attaching the video files I am referring to above.
file:obsr-game_2_9-27-18; https://tinyurl.com/yba6r4yx
file:replay_recording; https://tinyurl.com/y9znbp5w
file:update_test; https://tinyurl.com/y7zc3kxv
  • 2018-11-06 12-10-04.txt
  • 2018-11-06 16-38-25.txt
  • 2018-11-06 16-48-15.txt
  • 2018-11-07 09-09-12.txt
