Question / Help Avermedia LGP2 Providing Odd Video Quality
ProfessorNJ
Hey all,
I finally have got everything I wanted to get for my computer to run all my tasks both video editing and gaming. I have now encountered a big problem for myself which is the main reason I invested in building a computer was being able to use my Avermedia Live Gamer Plus 2 (GC513). I'm not certain if I overestimated my computer but, when I record my videos in obs they look:
1. Pixelated
2. Plays smooth for about 10 seconds then hops
3. Appears to skip some Frames via playback
4. Laggy Footage In General
I would like to believe that I have used every piece of information that I could find to help me, I have spent hours trying to solve the issue at this point I'm out of my depth. If there is someone with the answers I would greatly appreciate all the help you could give me. I have several logs
  • 2020-01-07 00-22-32.txt
Narcogen
Run the Auto-Configuration Wizard and it will suggest some settings for you.
Other notes:
00:22:33.362: YUV mode: 709/Full
Change this to 709/Partial.
https://obsproject.com/forum/resour...t-color-range-settings-guide-test-charts.442/
Use CRF rate control for local recording, with a CRF value between 14 (high quality) and 23 (good quality). CBR and a set bitrate is primarily for streaming.
The only time I see significant lag in the logfile is when you attempt to record 4k.
00:43:44.884: [x264 encoder: 'recording_h264'] settings:
00:43:44.884: rate_control: CBR
00:43:44.884: bitrate: 60000
00:43:44.884: buffer size: 60000
00:43:44.884: crf: 0
00:43:44.884: fps_num: 60
00:43:44.884: fps_den: 1
00:43:44.884: width: 3840
00:43:44.884: height: 2160
00:43:44.884: keyint: 250
00:45:56.625: Video stopped, number of skipped frames due to encoding lag: 3540/7893 (44.8%)
What are you playing back your recordings in?
