Big network issue
Hunteer05
Hello guys, I have a big issue with OBS, please someone can help me .
When i'm live , during streams, could be 2 minutes in or 2 hours, OBS causes my ethernet internet stop working suddendly.
This crash happens only when i'm in stream, i don't know what do it.
In attach , my network ethernet graphics when the iusse happens and the connection crash.
deFrisselle
Post an OBS log
What is your network setup Do you have a router or connect directly to cable modem, etc
Also, who is your service provider
Hunteer05
Thank you for reply.
I'm in Italy , my provider is Fastweb, sorry but now i'm not at home and i can't post an OBS log , this evening i will post it.
I have a 50mb in download and 8,5mb in upload, i have a Pc connect directly with my modem.
I tried do something else (play videogame, youtube ecc) and my connection not crashed , this happened only when i'm i stream. This issue happened when i used OBS the first time . Before with Streamlabs not crashed.
I don't know what is it , but is a big issue, is 3 day that i can't stream.
Hunteer05
Many thanks for reply, I don't know who to turn to .
This evening i will post an OBS logs and i hope to resolve the issue.
Hunteer05
this is my log file, i tried to stream now and the issue persist, please you can help me
  • 2021-02-18 17-29-56.txt
XpPe_Cris
I have the same problem for a few days now, I have the same Fastweb provider and the problem is the same when I go live after 1 minute or 1 minute and 25 crashes and the bitrates sent drop to 0, if you solved it, could you help me to understand the diagnostic problem please?
kriv4n
Anyone found a solution to this as well? I started having the same issue around that time in February and my ISP is Fastweb as well. Haven't been able to stream since then since my streams always drop frames and bitrate to 0 intermittently using Ethernet
Lawrence_SoCal
In general - OBS can't cause this problem.
Often, folks are unaware of how computationally demanding real-time video encoding is, and don't realize they are overloading their OBS computer, which then gets unstable. OBS isn't the issue... overloading the computer is the problem.
So you should be monitoring your computer to max sure you aren't resource constrained (CPU, GPU, RAM, Disk or Network I/O)
Then, realize that upload bandwidth numbers (from speedtests) are often highly optimistic, and do NOT represent the sustained, low jitter, bandwidth amount, hence the strong recommendation to not set your bitrate too close to your expected upload limit (leave some room for normal ebb and flow)
And then there are ISPs that can't/don't sustain that bandwidth (ie, there may be no issue at your house, or your connection at all). whether that applies in this circumstance depends on your specific ISP (Fastweb in this case)
One thing I've seen is people using either streamelements plugin or other browser based sources, not realizing how poorly written they are and the CPU is driven to 100% (or causes CPU thread locking) and that then causes havoc. This is NOT an OBS issue.
so for basic troubleshooting, I'd recommend a clean scene collection with no plugins active/running, and try a test stream. If that is stable, then you know (during that time at least, your computer, OBS, and your network are fine). And that should help you narrow down the source of the problem. If you still have problems, I'd start with making sure your OS and PC are up to the task (not an old, low-end CPU trying to do high resolution and frame rate, with filters, etc), that the OS is clean with unnecessary processes stopped/disabled (if resource contention is an issue).
With an RTX 3070, why aren't you using NVENC? [oh, later I see you did try it]
17:58:41.226: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 115 (0.7%)
17:58:41.226: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 743 (4.6%)
then later
18:00:02.258: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 46 (3.0%)
18:00:02.258: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 737 (50.0%)
Means you need to adjust your encoding settings
and you have a network problem of sending more data than your network allows (where in the network path the bottleneck is can't be determined by the OBS log). Is ANYTHING else (including your game) using upstream bandwidth (which includes TCP reply packets)?
