Bitrate fluctuating badly at random, frames dropping heavily
SpadesSystem
I'm a Twitch streamer, and I tried to go live today. My bitrate is typically around 3000, and last week I had zero issues with it. Today, my bitrate was fluctuating even in the starting screen when nothing was going on, going anywhere from 0 to 13000 and causing massive frame drops. I attempted to go live multiple times over the course of an hour and tried:
- Updating OBS
- Updating game drivers
- Changing games
- Restarting computer (multiple times)
- Restarting modem and router
Eventually I decided I wasn't going to be able to fix it in a timely manner and ended. I've attached all the relevant logs. Any help is greatly appreciated.
  • 2023-04-17 17-25-39.txt
  • 2023-04-17 17-29-03.txt
  • 2023-04-17 17-39-12.txt
  • 2023-04-17 17-40-17.txt
  • 2023-04-17 17-51-37.txt
  • 2023-04-17 18-01-25.txt
Hellegaard1
Dropped frames are due to internet connection instability. If you have Dynamic Bitrate checked under Advanced>Network it will auto adjust your bitrate up and down to help reduce or eliminate dropped frames.
Harold
Note: dynamic bitrate does not actually solve the underlying issue and can cause your stream encoder to crash if your connection is sufficiently unstable and you're using a hardware encoder.
