bitrate keeps going up and down for no reason
LighterZ
ive been streaming for a while with no issues and now all of a sudden my bitrate keeps dropping up and down, i even just bought a new router/modem and the issue persist. please help
  • 2024-09-08 19-31-49.txt
qhobbes
1. Your first log contains streaming session with dropped frames. This can only be caused by a failure in your internet connection or your networking hardware. It is not caused by OBS, it is caused by Twitch. JK, kinda. You had/have Enhanced Broadcasting enabled, which uses NVENC, enabled on that one which had 5 streams going at a total bitrate of 10200 audio and video. This was recently added in 30.2. You probably use to stream at 6000 video so didn't run into this issue. You can adjust settings by going Settings > Stream > Service: Twitch [Use Stream Key] >. Here you en/disable and adjust limits.
Your second log shows the Auto-config wizard test using x264 also at 10200 but as a single stream (and a lower audio bitrate too, 32 instead of 160). That 128 extra bitrate could lead to 8% dropped frames but kind of a stretch.
2. The Hardware-accelerated GPU scheduling ("HAGS") feature in Windows currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via these instructions.
3. In Windows, we recommend that "Game Mode" be enabled. Game Mode can be enabled via the Windows 10 "Settings" app, under Gaming > Game Mode.
4. Only use Display Capture if you need to capture Windows stuff such as desktop, start ment, taskbar, etc. If you are trying to capture a game, remove Display Capture from the scene and then add Game Capture. If you're having problems with that, run OBS as Admin. If that doesn't work, post a new log.
No to piggyback, but have you gotten anywhere with this? I've got the exact same situation. Started happening about 2 days ago too.
I also bought a new modem/router, and internet speeds are completely fine.
LighterZ
https://obsproject.com/logs/vAFjdLbdPJl1bLK1 im still having the same issue and its definitely not my internet could it be the new obs update?
qhobbes
1. OBS is not running as Administrator. This can lead to OBS not being able to Game Capture certain games. If you are not running into issues, you can ignore this, but it looks like you are so run OBS as Admin.
2. Display and Game Capture Sources interfere with each other. NEVER put them in the same scene.
3. Your log file is incomplete and only contains the start of a stream and recording. You need to stop those and then upload the log of the issue.
