Broadcast Audio Quality difference
jibephoto
When I record a few minutes locally and listen to the audio quality it sounds fine, but then when I broadcast to twitch there is something that is causing the audio to sound muffled or has a lot of static. Using a behringer UFO202 to capture the audio on my iMac. Have tested broadcasting to YouTube and the same audio quality happens. Have played around with changing bit rates and adding a compressor/limiter. Have tried all weekend long to find answers or anything to point me in the right direction.
Thanks in advance for any guidance
  • logfile.txt
