Question / Help Can't record at 4K at 60 FPS past 10K bitrate with out "High Encoding" on any setting.
Jm764
So sometime a month or two ago I upgraded from OBS Classic to OBS Stuido, and while I did manage to get my old Classic settings converted to Studio's new system, last month I made 2 major upgrades to my recording and PC setup that vastly expanded my recording and streaming capabilities.
So now I can use DSR to upscale my 1080p monitor to 2K and 4K res, but then I run into a problem.
No mater what setting I use I can't get my bit-rate past 10K without OBS starting to lag out.
Personally I'm not sure why this happens as I have a relatively high spec system considering so as far as most games go let alone any other program.
Here are my system specs:
CPU: i7-4790 (non "K") @3.6GHz (stock speed)
New GPU: Asus Geforce GTX 1070 STRIX OC (at stock speed).
"Current" GPU: Sapphire HD Radeon 7970 OC (at stock speed).
RAM: PNY Anarchy 16GB x2 (32GB) at 2133MHz
HDD: 120GB SSD and 3TB HDD
So is this system "too weak" to record at 4K after all or is there a setting(s) I can change to make OBS record better? I just want to get it to 15-20k bitrate as that seems to be the minimum I can do for the rather slow paced games I play, like Kerbal Space Program, Cities: Skylines, etc. I do play War Thunder and Need for Speed 2015 as well, but I barely get 60 fps at 4K in-game, so I'll only be recording those at 2K.
I'm on a trip atm and I could only bring the old Radeon HD 7970 with me so I won't really be able to test 4K untill i get back on the 26th of August, but if anyone has any ideas please let me know and I'll try them when I get back.
And for the record I DID TRY everything in the "Read this first" post before posting this before I left on my trip. Downscaling fixes it, but I want 4K "native" res.
Also I HAVEN'T tried streaming downscale at 720p while recording at 4K, but I'm pretty sure that would end badly anyway.
Thank you for your help,
Jason M.
Jm764
Post your OBS log please.
Well the oldest log I have was from the 5th, but the last time I recorded with the GTX 1070 at 4K was the 4th, so I don't have a log for that for some reason. :(
I can upload the log though as it might offer some insight anyway if you want.
Try using NVEnc with your 1070, it should support 4K encoding with 60 fps.
I think I did already, but I'll try it again when I get back from this trip. :)
Jm764
Well I'm back from my trip, but sadly the problems still persist.
The good news is I don't get high media encoding all the time when recording anymore at least for benchmarks and old games (from 2006 and older) and the fps is constant, but halved from what I see on my screen.
I also decommissioned my old gaming rig recently so I took the Radeon HD 7850 from it to my PC (mainly to add vga for a third monitor) and I can use that for encoding as well.
Sadly none of this can save the fps problems that persist when recording modern 3d games, let alone streaming.
Here's a video of what I see when this occurs:
https://www.youtube.com/watch?v=kYtAEEhCCD8
Here's the video it recorded (the stream version):
https://www.youtube.com/watch?v=uWGqZLRsQkc
And the stream recording (still uploading/processing atm):
https://youtu.be/Bx5kw_Uaoxg
At this point I can't think of anything that would work, so I'll probably just go back to 2K res recording again for everything. So if anyone knows what I can do or at least what's causing the problem, let me know.
Also anyone know how to record multiple different gpu monitors with obs? I have 3 screens and OBS only sees the main one.
Lastly the Radeon HD 7850 only seems to encode at 1080p max. If I set it to any resolution higher than that OBS won't even start recording. I can live with that, but anyone know why it won't work?
  • 2016-08-26 12-44-26 - Copy.txt
