Question / Help Choppy stream but no FPS drops or high encoding?
Pandurpz
Hello! I recently noticed that my streams look a bit choppy sometimes but I don't know why, I've changed settings to 1080p, NVENC, 6000 bitrate and my PC can handle it just fine, but even on 3000 bitrate, x264 and 720p it did the same thing. I originally noticed it on tomb raider, I assumed it was just the game. So I did some stress testing and saw it on Arma 3, Division 2, Overwatch. Rise of the tomb raider, shadow of the tomb raider, Fallout 76. I can run all of these games PERFECTLY fine, I usually use vsync to cap at 60fps, even if I turn down game graphics it happens, so I don't know where the issue is. There seems to be choppy gameplay but also some screen tearing sometimes, but only the stream sees it.
Specs:
1060 6gb
MSI B450 Gaming Plus
Ryzen 5 2600
16gb DDR4 2113 Mhz Vengeance LPX
  • 2019-05-02 16-47-05 Tomb Raider.txt
  • 2019-05-03 18-17-40 DivisonOverwatch.txt
Kenesen
my stream does the same thing ive done everything i can think of to fix it and nothing has worked so far
