Crash when i open OBS 28.1.2
ItzayHR
Nothing can be done at all. The moment I open OBS I get an error.
  • Crash 2022-11-07 20-32-47.txt
FranckB
do you have any plugins?
if so, uninstall OBS, delete the installation folder and that of AppData>Roaming>obs-studio
Then reinstall OBS 28.1.2
ItzayHR
Have you updated the GPU drivers?
Yes
ItzayHR
Yes, i have plugins
What is the problem with plugins? Because I have them since long before the problems.
FranckB
It is likely that your plug-ins do not work for version 28, check on the publisher's website and upgrade windows 10 to 22H2
