Bug Report Crash when stop stream
Kurogane
I'm having obs crahing when i click stop stream
This crash appears to have occured in the 'c:\program files (x86)\hma! pro vpn\bin\forceinterfacelsp.dll' module.
Fault address: 6DCE3E87 (c:\program files (x86)\hma! pro vpn\bin\forceinterfacelsp.dll)
OBS version: Open Broadcaster Software v0.571b
Windows version: 6.1 (Build 7601) Service Pack 1
CPU: AMD Phenom(tm) II X6 1090T Processor
Crashing thread stack trace:
Stack    EIP      Arg0     Arg1     Arg2     Arg3     Address
05D6F778 6DCE3E87 000003E3 00000000 05340DB0 00000000 forceinterfacelsp.dll!0x6dce3e87
05D6F790 6DCE3C3F 000002E4 05D6F804 76F79EF2 000002E4 forceinterfacelsp.dll!0x6dce3c3f
05D6F7C0 758033AA 000002E4 72B861AF 00000000 00000000 kernel32.dll!0x758033aa
05D6F7CC 76F79EF2 6DCE3BE0 000002E4 00000000 00000000 ntdll.dll!0x76f79ef2
05D6F80C 76F79EC5 6DCE3BE0 000002E4 00000000 00000000 ntdll.dll!0x76f79ec5
A minidump was saved to C:\Users\user\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-10-01_10.dmp.
List of loaded modules:
Base Address      Module
Seems is about my client of VPN software, before i don't have any issue now i'm getting this.
  • OBSCrashDump2013-10-01_10.dmp
R1CH
You will likely need to remove the VPN software to avoid the crash. Something OBS does in the latest releases is causing a lot of LSP DLLs to crash. You may want to contact the developer of your VPN software for assistance.
