Bug Report Crash while previewing stream
This1Noob
11:27:09: Open Broadcaster Software v0.624b - 64bit ( ^ω^)
11:27:09: -------------------------------
11:27:09: CPU Name: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
11:27:09: CPU Speed: 2492MHz
11:27:09: Physical Memory:  8075MB Total, 5079MB Free
11:27:09: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
11:27:09: monitor 1: pos={0, 0}, size={1920, 1080}
11:27:09: Windows Version: 6.2 Build 9200
11:27:09: Aero is Enabled
11:27:09: OBS Modules:
11:27:09: Base Address     Module
11:27:09: 00000000C7350000 OBS.exe
11:27:09: 000000003D270000 OBSApi.dll
11:27:09: 0000000047680000 DShowPlugin.dll
11:27:09: 00000000480E0000 GraphicsCapture.dll
11:27:09: 0000000047990000 NoiseGate.dll
11:27:09: 0000000042320000 PSVPlugin.dll
11:27:09: 0000000042300000 scenesw.dll
11:27:09: ------------------------------------------
11:27:09: Adapter 1
11:27:09:   Video Adapter: NVIDIA Quadro 2000M
11:27:09:   Video Adapter Dedicated Video Memory: 2080153600
11:27:09:   Video Adapter Shared System Memory: 4233746432
11:27:09:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
11:27:09: Adapter 2
11:27:09: =====Stream Start: 2014-06-01, 11:27:09===============================================
11:27:09:   Multithreaded optimizations: On
11:27:09:   Base resolution: 1920x1080
11:27:09:   Output resolution: 1280x720
11:27:09: Loading up D3D10 on NVIDIA Quadro 2000M (Adapter 1)...
11:27:09: Audio Format: 44100 Hz
11:27:09: Audio Channels: 2 Ch
11:27:09: Playback device Default
11:27:09: Using desktop audio input: Speakers (Conexant 20672 SmartAudio HD)
11:27:09: Global Audio time adjust: 0
11:27:09: Audio Encoding: AAC
11:27:09:     bitrate: 128
11:27:09: Using Monitor Capture
11:27:09: Scene buffering time set to 400
11:27:09: Video Encoding: x264
11:27:09:     fps: 60
11:27:09:     width: 1280, height: 720
11:27:09:     preset: veryfast
11:27:09:     profile: main
11:27:09:     keyint: 120
11:27:09:     CBR: yes
11:27:09:     CFR: yes
11:27:09:     max bitrate: 3500
11:27:09:     buffer size: 3500
  • OBSCrashLog2014-06-01_7.txt
  • OBSCrashDump2014-06-01_7.dmp
Lain
Lain
This crash is somewhat common on switchable graphics laptops running windows 8. There's not much I can do about it either because it's a nvidia -> intel inter-driver communication issue. You unfortunately do have to avoid monitor capture on laptops due to this fact.
