Question / Help Crashing When using H264/AVC (AMD Advanced Media Framework) Encoder
anji
hi there.. I am having a problem when using this codec or encoder...I don't want to use x264 since it makes the video choppy... So everytime i use this encoder and I press record it says the "woops, obs crashed" error and just crashes... is there any fix?
Crash log:
15:30:07.213: CPU Name: AMD A10-7870K Radeon R7, 12 Compute Cores 4C+8G
15:30:07.213: CPU Speed: 3893MHz
15:30:07.213: Physical Cores: 2, Logical Cores: 4
15:30:07.213: Physical Memory: 15281MB Total, 11533MB Free
15:30:07.213: Windows Version: 10.0 Build 10240 (revision: 16405; 64-bit)
15:30:07.213: Running as administrator: false
15:30:07.213: Aero is Enabled (Aero is always on for windows 8 and above)
15:30:07.213: Windows 10 Gaming Features:
15:30:07.213: Game Bar: Off
15:30:07.213: Game DVR: Off
15:30:07.213: Game DVR Background Recording: Off
15:30:07.217: Sec. Software Status:
15:30:07.220: Avast Antivirus: enabled (AV)
15:30:07.220: Windows Defender: disabled (AV)
15:30:07.221: Windows Firewall: enabled (FW)
15:30:07.222: Windows Defender: disabled (ASW)
15:30:07.222: Avast Antivirus: enabled (ASW)
15:30:07.224: Current Date/Time: 2019-06-02, 15:30:07
15:30:07.224: Browser Hardware Acceleration: true
15:30:07.224: Portable mode: false
15:30:08.010: OBS 23.1.0 (64-bit, windows)
15:30:08.010: ---------------------------------
15:30:08.012: ---------------------------------
15:30:08.013: audio settings reset:
15:30:08.013: samples per sec: 44100
15:30:08.013: speakers: 2
15:30:08.017: ---------------------------------
15:30:08.017: Initializing D3D11...
15:30:08.017: Available Video Adapters:
15:30:08.021: Adapter 1: Radeon (TM) RX 480 Graphics
15:30:08.021: Dedicated VRAM: 4274708480
15:30:08.021: Shared VRAM: 3717103616
15:30:08.021: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:30:08.021: Adapter 2: AMD Radeon(TM) R7 Graphics
15:30:08.021: Dedicated VRAM: 1039400960
15:30:08.025: Loading up D3D11 on adapter Radeon (TM) RX 480 Graphics (0)
15:30:08.071: D3D11 loaded successfully, feature level used: 45056
15:30:11.213: ---------------------------------
15:30:11.213: video settings reset:
15:30:11.213: base resolution: 1920x1080
15:30:11.213: output resolution: 1280x720
15:30:11.213: downscale filter: Bicubic
15:30:11.213: fps: 30/1
15:30:11.213: format: NV12
15:30:11.213: YUV mode: 601/Partial
15:30:11.213: NV12 texture support enabled
15:30:11.216: Audio monitoring device:
15:30:11.216: name: Default
15:30:11.216: id: default
15:30:11.217: ---------------------------------
15:30:11.222: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
15:30:11.224: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
15:30:11.857: [AMF] Version 2.5.1 loaded (Compiled: 1.4.9.0, Runtime: 1.4.12.0, Library: 1;4;12;0;18.50.17.01;201902011655;CL#1739124).
15:30:12.171: [AMF] [Capability Manager] Testing Direct3D 11 Adapter 'Radeon (TM) RX 480 Graphics (VEN_1002/DEV_67df/SUB_e347174b/REV_00c7)':
15:30:12.171: H264/AVC: Supported
15:30:12.171: H265/HEVC: Supported
15:30:12.171:
15:30:12.461: [AMF] [Capability Manager] Testing Direct3D 11 Adapter 'AMD Radeon(TM) R7 Graphics (VEN_1002/DEV_130f/SUB_130f1002/REV_00d4)':
15:30:12.461: H264/AVC: Supported
15:30:12.461: H265/HEVC: Not Supported
15:30:12.461:
15:30:12.873: [AMF] [Capability Manager] Testing Direct3D 9 Adapter 'Radeon (TM) RX 480 Graphics [\\.\DISPLAY1] (VEN_1002/DEV_67df/SUB_e347174b/REV_00c7)':
15:30:12.873: H264/AVC: Supported
15:30:12.873: H265/HEVC: Supported
15:30:12.873:
15:30:12.966: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
15:30:12.984: [obs-browser]: Version 2.3.1
15:30:13.856: LoadLibrary failed for '../../obs-plugins/64bit/scenesw.dll': The specified module could not be found.
15:30:13.856: (126)
15:30:13.856: Module '../../obs-plugins/64bit/scenesw.dll' not loaded
15:30:13.874: VLC found, VLC video source enabled
15:30:13.912: No blackmagic support
15:30:13.926: ---------------------------------
15:30:13.926: Loaded Modules:
15:30:13.926: win-wasapi.dll
15:30:13.927: win-mf.dll
15:30:13.927: win-dshow.dll
15:30:13.927: win-decklink.dll
15:30:13.927: win-capture.dll
15:30:13.927: vlc-video.dll
15:30:13.927: text-freetype2.dll
15:30:13.928: rtmp-services.dll
15:30:13.928: obs-x264.dll
15:30:13.928: obs-vst.dll
15:30:13.928: obs-transitions.dll
15:30:13.928: obs-text.dll
15:30:13.928: obs-qsv11.dll
15:30:13.928: obs-outputs.dll
15:30:13.928: obs-filters.dll
15:30:13.928: obs-ffmpeg.dll
15:30:13.928: obs-browser.dll
15:30:13.928: logi_obs_plugin_x64.dll
15:30:13.928: image-source.dll
15:30:13.928: frontend-tools.dll
15:30:13.928: enc-amf.dll
15:30:13.928: decklink-ouput-ui.dll
15:30:13.928: coreaudio-encoder.dll
15:30:13.928: ---------------------------------
15:30:13.961: ==== Startup complete ===============================================
15:30:14.077: All scene data cleared
15:30:14.077: ------------------------------------------------
15:30:14.199: WASAPI: Device 'Speakers (High Definition Audio Device)' initialized
15:30:14.219: WASAPI: Device 'Microphone (Blue Snowball )' initialized
15:30:14.261: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
15:30:14.261:
15:30:22.841: Switched to scene 'Minecraf'
15:30:22.875: ------------------------------------------------
15:30:22.875: Loaded scenes:
15:30:22.875: - scene 'Minecraf':
15:30:22.875: - source: 'Game Capture' (game_capture)
15:30:22.875: - scene 'Dekstop':
15:30:22.875: - source: 'Display Capture' (monitor_capture)
15:30:45.188: WASAPI: Device 'Microphone (Blue Snowball )' Terminated
15:30:45.238: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' initialized
15:30:45.252: Settings changed (audio)
15:30:45.253: ------------------------------------------------
15:30:45.267: adding 46 milliseconds of audio buffering, total audio buffering is now 92 milliseconds (source: Mic/Aux)
15:30:45.267:
15:30:45.427: adding 23 milliseconds of audio buffering, total audio buffering is now 116 milliseconds (source: Mic/Aux)
15:30:45.427:
15:33:42.347: Settings changed (outputs)
15:33:42.347: ------------------------------------------------
15:33:47.216: [AMF] [H264]<Id: 13> Encoder Parameters:
15:33:47.216: [AMF] [H264]<Id: 13> Backend:
15:33:47.216: [AMF] [H264]<Id: 13> Video API: Direct3D 11
15:33:47.216: [AMF] [H264]<Id: 13> Video Adapter: Radeon (TM) RX 480 Graphics (VEN_1002/DEV_67df/SUB_e347174b/REV_00c7)
15:33:47.216: [AMF] [H264]<Id: 13> OpenCL: Not Supported
15:33:47.216: [AMF] [H264]<Id: 13> Transfer: Disabled
15:33:47.217: [AMF] [H264]<Id: 13> Conversion: Disabled
15:33:47.217: [AMF] [H264]<Id: 13> Multi-Threading: Disabled
15:33:47.217: [AMF] [H264]<Id: 13> Queue Size: 8
15:33:47.217: [AMF] [H264]<Id: 13> Frame:
15:33:47.217: [AMF] [H264]<Id: 13> Format: NV12 601 Partial
15:33:47.217: [AMF] [H264]<Id: 13> Resolution: 1280x720
15:33:47.217: [AMF] [H264]<Id: 13> Frame Rate: 30/1
15:33:47.217: [AMF] [H264]<Id: 13> Aspect Ratio: 1:1
15:33:47.217: [AMF] [H264]<Id: 13> Static:
15:33:47.217: [AMF] [H264]<Id: 13> Usage: Transcoding
15:33:47.217: [AMF] [H264]<Id: 13> Quality Preset: Quality
15:33:47.217: [AMF] [H264]<Id: 13> Profile: High 3.1
15:33:47.217: [AMF] [H264]<Id: 13> Coding Type: Automatic
15:33:47.217: [AMF] [H264]<Id: 13> Max. Reference Frames: 4
15:33:47.217: [AMF] [H264]<Id: 13> Max. Long-Term Reference Frames: 0
15:33:47.217: [AMF] [H264]<Id: 13> Rate Control:
15:33:47.217: [AMF] [H264]<Id: 13> Method: Constant Bitrate
15:33:47.217: [AMF] [H264]<Id: 13> Pre-Pass Mode: Disabled
15:33:47.217: [AMF] [H264]<Id: 13> QP:
15:33:47.217: [AMF] [H264]<Id: 13> Range: 18 - 51
15:33:47.217: [AMF] [H264]<Id: 13> I-Frame: 22
15:33:47.217: [AMF] [H264]<Id: 13> P-Frame: 22
15:33:47.217: [AMF] [H264]<Id: 13> B-Frame: 22
15:33:47.217: [AMF] [H264]<Id: 13> Bitrate:
15:33:47.217: [AMF] [H264]<Id: 13> Target: 50000000 bit/s
15:33:47.217: [AMF] [H264]<Id: 13> Peak: 50000000 bit/s
15:33:47.217: [AMF] [H264]<Id: 13> Flags:
15:33:47.218: [AMF] [H264]<Id: 13> Filler Data: Enabled
15:33:47.218: [AMF] [H264]<Id: 13> Frame Skipping: Disabled
15:33:47.218: [AMF] [H264]<Id: 13> Period: 0 Frames
15:33:47.218: [AMF] [H264]<Id: 13> Behaviour: Skip every Nth frame
15:33:47.218: [AMF] [H264]<Id: 13> Variance Based Adaptive Quantization: Disabled
15:33:47.218: [AMF] [H264]<Id: 13> Enforce Hypothetical Reference Decoder: Enabled
15:33:47.218: [AMF] [H264]<Id: 13> Video Buffering Verfier:
15:33:47.218: [AMF] [H264]<Id: 13> Buffer Size: 50000000 bits
15:33:47.218: [AMF] [H264]<Id: 13> Initial Fullness: 100 %
15:33:47.218: [AMF] [H264]<Id: 13> Max. Access Unit Size: 0
15:33:47.218: [AMF] [H264]<Id: 13> Picture Control:
15:33:47.218: [AMF] [H264]<Id: 13> IDR: 60 Frames
15:33:47.218: [AMF] [H264]<Id: 13> I: 0 Frames
15:33:47.218: [AMF] [H264]<Id: 13> P: 0 Frames
15:33:47.218: [AMF] [H264]<Id: 13> B: 0 Frames
15:33:47.218: [AMF] [H264]<Id: 13> Header Insertion Spacing: 0
15:33:47.218: [AMF] [H264]<Id: 13> GOP Alignment: Enabled
15:33:47.218: [AMF] [H264]<Id: 13> Deblocking Filter: Enabled
15:33:47.218: [AMF] [H264]<Id: 13> Motion Estimation: Quarter, Half
15:33:47.218: [AMF] [H264]<Id: 13> B-Frames:
15:33:47.218: [AMF] [H264]<Id: 13> Pattern: 0
15:33:47.219: [AMF] [H264]<Id: 13> Delta QP: N/A
15:33:47.219: [AMF] [H264]<Id: 13> Reference: Disabled
15:33:47.219: [AMF] [H264]<Id: 13> Reference Delta QP: N/A
15:33:47.219: [AMF] [H264]<Id: 13> Intra-Refresh:
15:33:47.219: [AMF] [H264]<Id: 13> Number of Macroblocks Per Slot: 0
15:33:47.219: [AMF] [H264]<Id: 13> Number of Stripes: 0
15:33:47.219: ---------------------------------
15:33:47.220: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
15:33:47.220:
15:33:47.221: ---------------------------------
15:33:47.222: [FFmpeg aac encoder: 'Track2'] bitrate: 192, channels: 2, channel_layout: 3
15:33:47.222:
15:33:47.237: ==== Recording Start ===============================================
15:33:47.237: [ffmpeg muxer: 'adv_file_output'] Writing file 'D:/Raw Footage/2019-06-02 15-33-45.mp4'...
  • 2019-06-02 15-30-07.txt
