Cursor not showing in power point slide show
Tarun046
When i was using OBS in windows 7, i used to get a 'square' shaped bold cursor while recording ppt slide show, which was useful for me. But since i started using it on windows 10, i am not getting that square shaped or any other shaped cursor while writing and recording a ppt. Its just a small point shaped cursor which is not easy to track while recording a lecture. Is there any help that i can get to get back that 'square' shaped cursor or 'pencil' shaped cursor. I cannot use highlighter and laser in ppt, as i have to write down. And i want to avoid those yellow highlighted cursors also. I am attaching both image from windows 7 and windows 10 below.
Lawrence_SoCal
Microsoft updated some aspects of Display GUI, which impacts the Yellow Window border and things like cursor
Your Window/Display Capture method (there are options within those) impact cursor display, and whether you can turn on/off seeing the cursor
I have to go back to the older Win7 method of BitBlt so I could NOT see the cursor in a PPTx Windowed Slide Show
Tarun046
Sorry for such late reply, but do you have any solution for this now?
