Decklink Output Audio Drift
dmdb
I've had a good look through the forums here, Reddit as well but so far have not found a solution to this.
I am using OBS with a Blackmagic Duo 2 SDI card, using outputs only using the Decklink support built in to OBS. We are not streaming or recording within OBS, only using the Decklink output. Our sources are normally all browser sources, but for the purposes of testing this issue I have been using a local sync test pattern as a media source on loop which is a download from this Youtube video: https://www.youtube.com/watch?v=bCPEidaVzQU
We are normally using four separate instances of OBS, all running from their own directories in portable mode, however, if I run one instance, the issue is still present. We are encountering audio drift if we leave this sync test pattern (or our normal sources) running, if we leave it running over a period of 12 hours then there are 10 or more frames of audio delay on the outputs(measured by playing back frame by frame on an EVS). We see the following sort of line in the log and the delay does seem to correspond to these values:
13:25:54.566: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Media Source)
Most of the results I have found when searching for this issue refer to hardware overutilisation. Running Task manager we never see the CPU or GPU go higher than 50%, there is plenty of RAM spare etc so this does not appear as we see it to be the case but happy to accept suggestions to the contrary. If there was a constant number of frames delay we could deal with that but the drift is an issue. The amount of drift is arbitrary and I have been able to replicate this behaviour on a second identical machine.
I've attached a log file taken today from one of the OBS instances where there's a few lines shown, I have the instances running overnight as a fresh soak test with the only difference being that they are running with administrative rights as I found a suggestion that this can help with GPU access. This is running a fresh release of OBS from Github but we have experienced the same issue with the current release as well, hence trying a more up to date build to see if it made any difference.
Just wondering if anyone has encountered the same, or can offer any suggestions?
  • 2021-03-24 13-25-53.txt
peterjdej
We are using OBS for NarrowCasting and want to do this through an Atem switcher. First we tried it with NDI output and a Magewell NDI to SDI converter. That gave an audio issue. Audio was out of sync (known problem, reported at NDI plugin github). Other NDI sources (like Vmix) does not have that issue. Now we tried the Decklink mini monitor PCI card, directly connected at the Atem switcher. That gives the same issue as described above. After a fresh start of OBS, audio is in sync with video, but after a while it is running out of sync.
Hoggins!
Experiencing the exact same problem right now on a live session (no output encoding, just Decklink output). Any hint?
movingwater
Experienced the same today with my UltraStudio HD mini. I'm on macOS and if I output the sound direkt to the UltraStudio the sound is more or less in sync. But if I output it through OBS with the blackhole virtual audio device sound is off almost a 1sec (30fps). Sound is behind 1 sec.
dmemphis
Experiencing similar audio sync issue on a decklink mini monitor card, playing a list of files with "VLC video source". I was suspecting it to be VLC, but now I suspect it is OBS based on what I see here. This is a critical problem for us now.
  • 2022-01-08 11-06-34.txt
video2go
Hi,
I am using RPI4 to play SRT streams to my old ATEM TV Switcher (1080i50) from HDMI. Having Blackmagic Decklink mini monitor I wanted to use OBS and Decklink out to HDMI to my ATEM TV Studio but there is a huge audio drift so all my program had asynchronous problems.
Any workarounds?
lindenkron
Hi,
Any workarounds?
Am also experiencing major issues with this. It appears there's no solid solutions neither NDI nor SDI (Decklink) that does not come with audio sync complications.
Originally we used NDI and ran into drifting audio syncs, with buffering showing up in the logs as well. Then we've gone and purchased Decklinks for direct PC to PC SDI connection only to find that it's awfully out of sync as well. Having gone through every settings a multitude of time, I keep coming back it to simply being an OBS issue.
Worst part is that it seems to randomly work at times (no delay) then suddenly we're back to 1~ sec delay on video, and audio lagging behind by a whole second. Tragic having purchased hardware and then it turns out it's software issues :(
HSX
Hi !
The only thing I found to solve the problem at the moment is to use an audio embedder (Like the Audio to SDI blackmagic ones) to have both the audio & video sync. I didn't find any software solutions at the moment. Since it's only the audio that drifts but not the video it works perfectly.
Typically what I do is plug the Focusrite Line Outputs into the Audio Embedder along with the Decklink SDI Output.
Have been running a test for two days with a high GPU & CPU use and there's still no audio drift so it seems to work.
I'm still hoping for a fix but it works !
Gabriel Nogales
I have the same problem, I see you had it quite a while ago. Did you manage to solve it?
DRI374
I have the same issue with the UltraStudio Monitor 3G on OBS 31.0.0 using a MBP M3 Max. Stopping and starting the Decklink output in OBS seems to fix it but it's not a feasible solution because I have no way to tell if the sound is out of sync or not as it's going into a recorder.
DRI374
Too late for edit,it appears the video is lagging in my case and I needed to nudge it 53 frames (60fps) to sync up.
konsolenritter
Hi !
As always said in the forum the audio desync issues were induced by different (unsynced) clocks (oszillators) driving the different soundcards. So aside of classical dropouts (missing audio chunks, what should be the case very seldom) the issue arises by (the receiving) one audio card expecting audio faster (or slower) in its play buffer than the audio device on the source side of connection could deliver it. That could be the case within obs too while having an obs internal clocking loop (in the mixing and final stage) and different clocked physical inputs (like the soundcards or external sound devices of that computer).
Why does the audio embedder magically fix this? ...Right. Its just another kind of a soundcard. It takes analog audio (from wherever) and embeds it after another ADC process into the digital video stream. The clock of this ADC is derived... well... from the clock and speed of the SDI link used. So its another digital-analog-digital conversion with a retiming of the source audio entering the link. The sink (destination) of the link then is bound to the clock of the link as well, so both "soundcards" (the one in the embedder and the one of the links far end) are bound to the same clock. Due to the DADCs retiming the audio timing went independent from the digital clocking of the former source (before the link). Thats for the embedder and why it solves such things often.
In generic terms the issue itself is not completely sourced in software but in (different) hardware driven by different clocks. The final conclusion indeed is that it could/should been resolved in software. Well, that's the basic idea of Norihiros Asynchronous Audio Filter which tries to adapt sources audio stream to the final obs internal clockloop by dropping or inserting a sample here and then:
Some people reacted that it solves their issue, others not.
A proof for that i'm right with my assumptions would be a chain of two computers with different audio cards that definitely ran into the buffering trouble. And then in a second step to check if that happens again with both audio devices synched external to a common clock. This principle is named "houseclock" and the usual solution in radio and tv stations. Hence audio devices with external sync clock possibilities are not the cheapest one, unfortunately.
