Question / Help Dedicated Steam PC/R Ryzen 5 2600 High CPU usage & Encoding lag
bebop_anonymous
I am kinda at my wits end trying to troubleshoot this issue.
OBS is being super intermittent, some streams I can run on all the way to SLOW and no issues and the CPU never runs above 50%. Then other streams I can barely go above VERY FAST. Its not overclocked, my bios is up to date and I have a 1060 to back it up....so what the hell is going on? If anyone can help I would be beyond grateful, its irritating to spend the money on a 2nd dedicated stream PC for this to happen. Once again, this is JUST a dedicated stream pc, I only run OBS and Spotify on this.
SPECS:
Ryzen 5 2600
Asus GTX 1060 3gb
Asus Prime B450
1 x 8gb Patriot 2666mhz
256 SSD
Elgato HD60s
Base Res: 1920x1080
Output Res: 1600x900
Bicubic
60fps
6k bitrate
The logs I have posted are all from test streams, if anyone needs any other info let me know...and once again thank you.
  • 2020-01-12 01-01-02.txt
  • 2020-01-12 09-21-55.txt
  • 2020-01-12 09-34-24.txt
  • 2020-01-12 09-52-12.txt
