Question / Help Despite high settings, video output is terrible.
Brian H
Hello! I seem to be having trouble producing quality 1920 x 1080 recordings... with my GTX 1080. Naturally, I'm a bit confused.
I've attached my DxDiag txt file as well as my MSInfo txt file. Hopefully this should provide enough knowledge of my system, otherwise, I'm willing to go further to help incase I missed anything. I've also attached screenshots of my OBS settings and will provide a link to an example of what OBS records.
Below is a video of some recorded gameplay in which I purposefully turned off the sound. Despite me running the game at well over 100FPS at any given moment on its absolute highest settings, and the recording itself coming out at 60FPS, the quality is near unwatchable at times, despite the video being uploaded in 1080P60FPS on Youtube as well.
Any help would be appreciated because, strangely, if I stream, the issue doesn't really exist, but I don't intend to really stream that much. Thanks in advance!
Youtube link: https://youtu.be/0shThD4-s_w
Edit: here is my log file link.
https://gist.github.com/176a678f3793a192e3b067679a6c9c3c
Advanced.PNG Output Recording Advanced.PNG Video.PNG Advanced.PNG Output Recording Advanced.PNG Video.PNG
  • DxDiag.txt
  • MSInfo.txt
Harold
Those are actually some pretty terrible recording settings.
And the log you provided doesn't show a recording attempt.
Try again with Settings - output
Simple output mode
indistinguishable recording quality
FLV format (there are precisely ZERO situations where mp4 is appropriate)
software (x264 low cpu use preset) encoder
Do a test record with those settings
Then restart obs and upload the LAST log from the help menu and link it here.
Harold
That's an incomplete log from a session where you tried to launch a second instance of OBS.
FingerMove
Why even bother with OBS when you have a GTX 1080 that can use hardware-level encoding directly in itself? Just use Geforce Experience with NVidia Share and get 60 fps@your native resolution with zero lag and much better quality than what your CPU can achieve.
People these days...
