Disconnecting irregularly
melad
Hi, i am encountering some issues, it has happened a few times that the program is disconnected !!
I use the OBS Studio for livestreaming via Restream.io to both Youtube & Facebook
I'm attaching log-file
  • 2020-06-07 11-14-24.txt
R1CH
12:57:10.943: [rtmp stream: 'simple_stream'] Interface: Intel(R) Dual Band Wireless-AC 8265 (802.11, 144 mbps)
12:57:18.254: [rtmp stream: 'simple_stream'] Interface: ThinkPad USB-C Dock Gen2 Ethernet (ethernet, 1000 mbps)
It looks like you have flapping interfaces, either your Ethernet dock is going down which forces a connection over Wifi or vice versa. I would suggest disabling Wifi and verifying your dock Ethernet connection is working correctly.
