Question / Help Dropping frames without a reason
Randomjoentje
hello,
(sorry for my bad typing english)
so the title says it all. when i stream i will be dropping frames after like 40 min not in big numbers but starting slow and will rise to 0.4% and its really frustrating me
here are some of my pc specs:
Intel Core i7 7700 @ 3.6GHz
32,0GB Dual-Channel DDR4
MSI RTX 2070 Armor 8GB
ASRock H270M-ITX/ac
im streaming 720p60fps with an 3500/4000 bitrate
i have a upload speed of 25.40
i attached a log of todays stream
  • 2019-12-02 14-11-44.txt
Narcogen
You dropped more frames from other sources than network lag:
16:15:41.198: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 1177 (0.3%)
GPU Overload Issues
16:15:41.198: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 1695 (0.4%)
16:15:45.343: Output 'adv_file_output': stopping
16:15:45.344: Output 'adv_file_output': Total frames output: 416523
16:15:45.344: Output 'adv_file_output': Total drawn frames: 415594 (416771 attempted)
16:15:45.344: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 1177 (0.3%)
16:15:45.345: ==== Recording Stop ================================================
16:15:45.349: Video stopped, number of skipped frames due to encoding lag: 2628/416769 (0.6%)
General Performance and Encoding Issues
Randomjoentje
GPU Overload Issues
could it be a problem that i have a internet browser open?
Narcogen
If that's the cause of the extra CPU and GPU load that means the difference between safe and stable performance and noticeable frame drops, then I'd say you're running on specs that are too close to the edge.
Randomjoentje
but i switched from twitch to mixer and since i play cod mw i have these problems
