Bug Report Elgato 4k60 Pro - Weird Network Performance?
Draco
OBS Log: (attached)
Issue at hand:
FYI - this is a 2 PC setup. Outside of my continuing battle with Spectrum and their lack of consistent speeds with drop-outs, I've noticed a weird bandwidth thing going on when I enable my Elgato 4K60 Pro capture card in OBS Studio 22.0.2 (64bit). Screenshots speak 1000 words, so here you go:
You can see when I disable and then enable the Elgato capture source as it goes all spiky, the outbound bandwidth goes nuts for some reason. Is this intended or could this be a driver or buffer bug perhaps?
Any insight on this or maybe something to try to reduce the impact is greatly appreciated. If you need more information on my setup, give a quick shout.
  • obslog.txt
