Encoder error occured while streaming?(right after i press stream)
UnDragonized
Hey this is a fairly new problem ive never had before, my dad gave me a PC (used parts) it has a GTX 980 for my graphics card so it should stream fine but everytime i clic stream to test it, it says their an error, i cant stream in x264 unless i disable and re enable my drivers,
Heres the log:
  • 2022-03-18 16-25-04.txt
Insufficient Hardware. It's the CPU
cyclemat
UPDATE YOU GPU DRIVERS FORM THE NVIDIA SITE
16:25:04.523: Malwarebytes: enabled (AV)
deinstall it !!!
1st you have select the wrong GPU
16:26:17.185: warning: The selected preset is deprecated. Use p1 to p7 + -tune or fast/medium/slow.
16:26:17.185: fatal: No capable devices found
16:26:17.185: [NVENC encoder: 'streaming_h264'] Failed to open NVENC codec: Generic error in an external library
16:26:17.185: Stream output type 'rtmp_output' failed to start! Last Error: Failed to open NVENC codec: Generic error in an external library
16:26:17.185:
16:26:17.185: You have selected GPU 1 in your output encoder settings. Set this back to 0 and try again.
6:26:17.185: GPU: 1
set it to 0
2nd. your settings are bad look at the table
16:26:17.185: width: 1920
16:26:17.185: height: 1080
16:26:17.185: bitrate: 4500
16:25:06.148: fps: 60/1
16:26:57.850: [rtmp stream: 'adv_stream'] Interface: TRENDnet N600 Wireless Dual Band PCIe Adapter (802.11, 144 mbps)
dont use a wirless connection streaming needs a stable connection and wifi ist not stable interferenc and many other things like any body send you a video via whatsapp!
