Encoding Overloaded for Warzone
Backros
Thank you for taking some time on my problem, I really appreciate it.
I have an "Encoding Overloaded" issue with my OBS.
This is My recent log: https://obsproject.com/logs/vvstVqICvZju7bpy
I am trying to record and stream at the same time with my GTX 1660 using Nvenc encoding, I have the low settings for Warzone.
The funny thing is that after a custom the frames rate to 60 although I can get up to 90 it will work just fine, but when I change the frames to 70 or 80 FPS in-game, it will start giving me the error.
It was working fine before, but I just can't get it to work now.
Things I Did to fix my issue and did not help:
*I run OBS as ADMIN
*Change OBS64.exe above normal on priority in task manager
*Game mode OFF
*OBS reinstallation
*Graphic Card Update to the latest
*Pray for a Miracle.
Would someone advise me on what im doing wrong, please?
Here are some pictures of my setting in OBS
Thank you
