Encoding overloaded! Stream, play & record configuration issues!
chomlee
PC:
Ryzen 5 2600
16gb ram
GPU: RX 570 4gb
Hi all, i am trying to stream in 720p/60 fps to youtube and record the session concurrently, however i am unable to find the right setting to achieve that. I tried using X264 to stream and H264/AVC for recording, and vice versa, and still i am getting encoding overloaded problem. I am wondering if i simply cannot achieve that using one PC setup, or the limitation of my GPU or am i doing anything wrong? Any advice will be much appreciated. thanks!
The game i was playing is "Locked up", indie horror game, on a medium graphic settings, and 60 FPS.
Please refer to the log file showing test done using X264 to stream & H264/AVC for record, and vice versa.
THANKS!
  • 2021-04-03 11-48-56.txt
