Question / Help Error installing bitrate setting calculator
Dario Marco
Hi, I installed the bitrate 1.0 calculator script but I can't see anything, and I also get this error:
[obs-bitrate-settings-calculator.lua] Error while executing the file: ... ontend-tools / scripts / obs-bitrate-settings-calculator.lua: 26: dlopen (libobs.dylib, 5): image not found
how should I go to solve?
Greetings
elenabrunner
If you search for "bitrate calculator" on Google, the first result that appears is: and there's a beautiful little java calculator - you'll need to install Java in order to use this calculator Mehrwertsteuer Rechner.
The 4.37(DVD5) option should not be confused with the 4.37GB of available space on the computer.
The next issue is how much space to leave for menus. If there are only a few simple menus, you can probably use a little less than the calculated amount; if the menus are complex (with animated thumbs, motion backgrounds, etc.), you might need to do a trial prepare of just the menu using a dummy movie or movies to see how much space they will take up.
Additionally, depending on the material, there may not necessarily be many benefits to aiming for the highest bitrate. Furthermore, certain players may experience playability problems when the bitrate is increased to maximums, such as 9603 kb/s.
elenabrunner
Google's first result for "bitrate calculator" is this lovely little Java calculator; however, in order to use the Mehrwertsteuer Rechner calculator, Java must be installed.
It is important to distinguish between the 4.37(DVD5) option and the computer's 4.37GB of accessible space.
