(Facebook level up stream)CSGO stream is not smooth 60fps on the viewers.
nielcutters
Hi i've been streaming fb.gg level up program which means i can stream 60fps 1080p. But my problem is it's not like the other streamers videos, Their fps on their stream is really smooth compared to mine. DL and Upload speed is at 200mbps. For example CSGO: between switching weapons and knives, it's really crisp and smooth (no tearing) but in my stream it feels like it's not 60fps. There is no problem with IN GAME FPS, no tearing in game and no jittering as well. The only problem is my stream video outputs. Seems like it's not 60fps. I hope someone could help me with this.
CHECK my video: https://www.facebook.com/strafolaTV/videos/1130126253846960/
MY FRIEND's video (he's on a low end PC) and I already asked him. Copied his obs settings, still doesnt work.
CHECK his video: https://www.facebook.com/SolutionPH/videos/454794745074935/
my obs settings:
Advanced:
Encoder: NVENC (new) enforce streaming service encoder settings (checked)
CBR
bitrate: 6000
CPU: Quality
profile: none
tune: none
LOGS:
13:04:30.641: base resolution: 1920x1080
13:04:30.641: output resolution: 1920x1080
13:04:30.641: downscale filter: Bicubic
13:04:30.641: fps: 60/1
LOG:
13:04:29.552: CPU Name: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
13:04:29.552: CPU Speed: 2808MHz
13:04:29.552: Physical Cores: 6, Logical Cores: 6
13:04:29.552: Physical Memory: 24494MB Total, 20487MB Free
13:04:29.552: Windows Version: 10.0 Build 18362 (revision: 267; 64-bit)
13:04:29.552: Running as administrator: false
13:04:29.552: Aero is Enabled (Aero is always on for windows 8 and above)
13:04:29.552: Windows 10 Gaming Features:
13:04:29.552: Game DVR: On
13:04:29.554: Sec. Software Status:
13:04:29.555: Windows Defender Antivirus: enabled (AV)
13:04:29.556: Windows Firewall: enabled (FW)
13:04:29.556: Current Date/Time: 2019-08-07, 13:04:29
13:04:29.556: Browser Hardware Acceleration: true
13:04:29.556: Portable mode: false
13:04:29.757: OBS 23.2.1 (64-bit, windows)
13:04:29.757: ---------------------------------
13:04:29.757: audio settings reset:
13:04:29.757: samples per sec: 44100
13:04:29.757: speakers: 2
13:04:29.759: ---------------------------------
13:04:29.759: Initializing D3D11...
13:04:29.759: Available Video Adapters:
13:04:29.762: Adapter 0: NVIDIA GeForce GTX 1060 6GB
13:04:29.762: Dedicated VRAM: 2051014656
13:04:29.762: Shared VRAM: 4252385280
13:04:29.762: output 0: pos={0, 0}, size={1920, 1080}, attached=true
13:04:29.762: output 1: pos={1920, 0}, size={1920, 1080}, attached=true
13:04:29.764: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 6GB (0)
13:04:29.807: D3D11 loaded successfully, feature level used: 45056
13:04:30.641: ---------------------------------
13:04:30.641: video settings reset:
13:04:30.641: format: NV12
13:04:30.641: YUV mode: 601/Partial
  • 2019-08-07-13-04-29.txt
