I have a problem with my Facecam. The problem occurred when I got my new computer. So on my other computer, my facecam would always record in 60fps no problem. Never changed anything about it in the settings. But now with my new PC I had to reinstall OBS and everything. But now my Camera isn't at 60fps anymore. If I go into Propperty's and try to change it to 60. Well, I don't even have the option to go to 60. If I use the highest then it still is 30fps. And the weird thing, I plugged it into my fastest computer port
The facecam that I have is the Logitech c920 pro. And well, it should be able to record in 60fps I read. And experienced it already. Does anyone have a fix for this problem? I've been breaking my neck on this one for the past 2 hours for crying out loud
AaronD
But how is it possible that I then recorded it with 60fps already? Like, I am 99% sure it always was at 60 yk
If the source is 30 and the destination is 60, then each frame is probably just duplicated. The destination is indeed 60, except for that duplication, so it's visibly 30. Can you *actually* tell the difference? If there's not much motion, probably not.
Kinda like a lot of film formats having 24 images per second, while the projector flashed each one 3 times before moving the film to make it look that much smoother. 24 frames per second, but 72 flashes per second.
