Failed to connect error
lstolk
I tried to stream and received the error:
"Could not access the specific channel or stream key, please double-check your stream key. If it is correct, there may be a problem connecting to the server."
I'm logged in with Twitch.
I tried the following:
  • Run OBS with administrator rights
  • Bind to IP
  • Update to latest version
  • Check file integrity
  • Select a server instead of using default
  • Add OBS to firewall private and public
  • Temporarily disabled my firewall
  • Switched and disabled my DNS
  • Restart everything
Is there something else I could try?
  • 2024-03-11 20-07-42.txt
lstolk
I tried my neighbours wifi, which didnt work. When I used my phone as hotspot, it worked. What router setting is causing the problem?
