Hi there, and thanks for the amazing work on OBS.
I’d like to suggest a UI improvement that could prevent common mistakes related to audio monitoring settings.
Currently, when a source is set to “Monitor Only (mute output)”, the audio meters still show activity, which is very useful — but also potentially misleading. Many users (like myself) assume that if the meter is active, the audio is included in the recording or stream.
Request:
Would it be possible to add a small icon or visual indicator next to each audio meter that shows:
Thanks again for your time and for keeping OBS awesome.
Emilio
Request:
- if the source is being monitored
- or ⛔ if the source is included/excluded from the main output (Program Mix)
Emilio
