Fixing OBS won't start after adding an audio source
QCWiz
I managed to solve this by changing the input in pavucontrol or sound settings. I switched my input, then tried starting OBS. If it doesn't work, change input and repeat. OBS finally opened with my webcam as an audio input. Then, make sure to remove the audio input from OBS.
It was a very scary problem, as other reports say it will continue even after purge/reinstalling.
Full error log (also in attached):
qt5ct: using qt5ct plugin
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale/fr-FR.ini
Attempted path: /usr/share/obs/obs-studio/locale/fr-FR.ini
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: CPU Name: AMD Ryzen 5 3600X 6-Core Processor
info: CPU Speed: 1916.130MHz
info: Physical Cores: 6, Logical Cores: 12
info: Physical Memory: 15935MB Total, 11967MB Free
info: Kernel Version: Linux 5.4.0-67-generic
info: Distribution: "Linux Mint" "20.1"
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.9
info: Portable mode: false
qt5ct: D-Bus global menu: no
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_actionGridMode_triggered()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
QMetaObject::connectSlotsByName: No matching signal for on_transitionRemove_clicked()
info: OBS 26.1.1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
info: Initializing OpenGL...
info: Loading up OpenGL on adapter AMD Radeon RX 580 Series (POLARIS10, DRM 3.35.0, 5.4.0-67-generic, LLVM 12.0.0)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 21.1.0-devel (git-b992b38 2021-03-22 focal-oibaf-ppa), shading language 4.60
info: video settings reset:
base resolution: 1920x1080
output resolution: 1280x720
downscale filter: Bicubic
fps: 30/1
format: NV12
YUV mode: 709/Partial
info: NV12 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
info: No blackmagic support
info: [obs-browser]: Version 2.9.1
info: [obs-browser]: CEF Version 76.1.13+gf19c584+chromium-76.0.3809.132
error: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: cannot open shared object file: No such file or directory
info: FFMPEG VAAPI supported
info: VLC found, VLC video source enabled
info: Loaded Modules:
info: vlc-video.so
info: text-freetype2.so
info: rtmp-services.so
info: obs-x264.so
info: obs-vst.so
info: obs-transitions.so
info: obs-outputs.so
info: obs-libfdk.so
info: obs-filters.so
info: obs-ffmpeg.so
info: obs-browser.so
info: linux-v4l2.so
info: linux-pulseaudio.so
info: linux-jack.so
info: linux-decklink.so
info: linux-capture.so
info: linux-alsa.so
info: image-source.so
info: frontend-tools.so
info: decklink-ouput-ui.so
info: decklink-captions.so
error: os_dlopen(../obs-plugins/obs-browser->../obs-plugins/obs-browser.so): ../obs-plugins/obs-browser.so: cannot open shared object file: No such file or directory
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'pulseaudio 13.99.1'
info: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_output.pci-0000_0b_00.4.analog-stereo.monitor'
info: [Loaded global audio device]: 'Desktop Audio'
error: pulse-input: An error occurred while getting the source info!
info: [Loaded global audio device]: 'Mic/Aux'
error: alsa-input: Failed to open 'front:CARD=Device,DEV=0': Device or resource busy
warning: xnack 'Off' was requested for a processor that does not support it!
[swscaler @ 0x5644e09e7a80] deprecated pixel format used, make sure you did set range correctly
[swscaler @ 0x5644e08e0a40] deprecated pixel format used, make sure you did set range correctly
info: xcompcap: [window-capture: 'ChessWindow'] update settings:
title: Bug Report - fails to start | OBS Forums — Mozilla Firefox
class: Navigator
Bit depth: 32
Found proper GLXFBConfig (in 368): yes
[swscaler @ 0x5644e0987c00] deprecated pixel format used, make sure you did set range correctly
warning: Failed to open file '/home/wsl/Documents/Travail/Formation OBS OSVE/Thanos/Webcam_Frame_Thanos2.png': No such file or directory
warning: gs_image_file_init_internal: Failed to load file '/home/wsl/Documents/Travail/Formation OBS OSVE/Thanos/Webcam_Frame_Thanos2.png'
warning: [image_source: 'TVcadre'] failed to load texture '/home/wsl/Documents/Travail/Formation OBS OSVE/Thanos/Webcam_Frame_Thanos2.png'
info: v4l2-input: Start capture from /dev/video0
info: v4l2-input: Input: 0
info: v4l2-input: Resolution: 640x480
info: v4l2-input: Pixelformat: YUYV
info: v4l2-input: Linesize: 1280 Bytes
info: v4l2-input: Framerate: 30.00 fps
info: xshm-input: Geometry 1920x1080 @ 0,0
info: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Desktop Audio)
Segmentation fault (core dumped)
  • 2021-03-22 15-22-08.txt
