FPS DROP WHEN RECORDING VALORANT
Brrttboi
I'm running on a RTX 2060, Ryzen 5 2600x, 16gb ram, and B450-M, but everytime I record valorant my fps drops from 200 stable to 80-90 for some reason. I also tried monitoring my task manager for GPU% and it goes up around 65%.
Here are the logs for the times it fps dropped.
  • 2020-08-03 01-19-30.txt
  • 2020-08-03 00-42-13.txt
  • 2020-08-02 23-44-45.txt
  • 2020-08-02 23-44-03.txt
Alex_Doss
I looked at the logs and found what I think is causing your issue.
00:45:18.803: [game-capture: 'Game Capture'] attempting to hook process: VALORANT-Win64-Shipping.exe
00:45:18.806: [game-capture: 'Game Capture'] init_hook_info: user is forcing shared memory (multi-adapter compatibility mode)
00:45:18.819: [game-capture: 'Game Capture'] capture stopped
It seems like OBS is having an issue finding Valorant, I would suggest using windows capture and making sure Valorant is in fullscreen and see if that works.
