23:50:27: CLR host plugin strings not found, dynamically loading 4 strings
23:50:27: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
23:50:27: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
23:50:27: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
23:50:27: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
23:50:27: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
23:50:27: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
23:50:27: CLRHost:: Could not find/load browser settings at location C:\Users\User\AppData\Roaming\OBS\pluginData\browser.json
23:50:27: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\User\AppData\Roaming\OBS\pluginData\browser.json'.
23:50:27: File name: 'C:\Users\User\AppData\Roaming\OBS\pluginData\browser.json'
23:50:27: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
23:50:27: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
23:50:27: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
23:50:27: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
23:50:27: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
23:50:27: Video Source Plugin strings not found, dynamically loading 52 strings
23:56:16: CLR host plugin instance deleted; removing dynamically loaded localization strings
23:56:16: Video Source Plugin instance deleted; removing dynamically loaded localization strings
Last game capture log:
2016-04-17, 22:43:31: we're booting up:
22:43:31: CaptureThread: attached to process bf4.exe
22:43:31: DXGI Present
22:43:31: (half life scientist) everything.. seems to be in order
22:43:31: DXGI: Found D3D 11
22:43:31: setting up d3d11 data
22:43:31: ---------------------- Cleared D3D11 Capture ----------------------
22:43:31: found dxgi format (dx11) of: 28, size: {1280, 720}, multisampled: false
22:43:31: DoD3D11Hook: success
22:43:31: successfully capturing d3d11 frames via GPU
22:43:35: ---------------------- Cleared D3D11 Capture ----------------------
22:43:36: DXGI: Found D3D 11
22:43:36: setting up d3d11 data
22:43:36: ---------------------- Cleared D3D11 Capture ----------------------
22:43:36: found dxgi format (dx11) of: 28, size: {1920, 1200}, multisampled: false
22:43:36: DoD3D11Hook: success
22:43:36: successfully capturing d3d11 frames via GPU
22:43:38: ---------------------- Cleared D3D11 Capture ----------------------
22:43:38: DXGI: Found D3D 11
22:43:38: setting up d3d11 data
22:43:38: found dxgi format (dx11) of: 28, size: {1280, 720}, multisampled: false
22:43:38: DoD3D11Hook: success
22:43:38: successfully capturing d3d11 frames via GPU
22:43:42: ---------------------- Cleared D3D11 Capture ----------------------
22:43:43: DXGI: Found D3D 11
22:43:43: setting up d3d11 data
22:43:43: ---------------------- Cleared D3D11 Capture ----------------------
22:43:43: found dxgi format (dx11) of: 28, size: {1920, 1200}, multisampled: false
22:43:43: DoD3D11Hook: success
22:43:43: successfully capturing d3d11 frames via GPU
22:45:23: D3D9 Present
22:46:29: ---------------------- Cleared D3D11 Capture ----------------------
22:46:30: DXGI: Found D3D 11
22:46:30: setting up d3d11 data
22:46:30: ---------------------- Cleared D3D11 Capture ----------------------
22:46:30: found dxgi format (dx11) of: 28, size: {1280, 720}, multisampled: false
22:46:30: DoD3D11Hook: success
22:46:30: successfully capturing d3d11 frames via GPU
22:46:33: stop requested, terminating d3d11 capture
22:46:33: ---------------------- Cleared D3D11 Capture ----------------------
22:46:49: DoD3D11Hook: success
22:46:49: successfully capturing d3d11 frames via GPU
22:46:51: ---------------------- Cleared D3D11 Capture ----------------------
22:46:52: DXGI: Found D3D 11
22:46:52: setting up d3d11 data
22:46:52: ---------------------- Cleared D3D11 Capture ----------------------
22:46:52: found dxgi format (dx11) of: 28, size: {1920, 1200}, multisampled: false
22:46:52: DoD3D11Hook: success
22:46:53: successfully capturing d3d11 frames via GPU
22:47:36: ---------------------- Cleared D3D11 Capture ----------------------
22:47:36: DXGI: Found D3D 11
22:47:36: setting up d3d11 data
22:47:36: found dxgi format (dx11) of: 28, size: {1280, 720}, multisampled: false
22:47:36: DoD3D11Hook: success
22:47:36: successfully capturing d3d11 frames via GPU
22:47:39: stop requested, terminating d3d11 capture
22:47:39: ---------------------- Cleared D3D11 Capture ----------------------
22:48:08: DoD3D11Hook: success
22:48:08: successfully capturing d3d11 frames via GPU
22:48:10: ---------------------- Cleared D3D11 Capture ----------------------
22:48:11: DXGI: Found D3D 11
22:48:11: setting up d3d11 data
22:48:11: ---------------------- Cleared D3D11 Capture ----------------------
22:48:11: found dxgi format (dx11) of: 28, size: {1920, 1200}, multisampled: false
22:48:11: DoD3D11Hook: success
22:48:11: successfully capturing d3d11 frames via GPU
22:52:34: ---------------------- Cleared D3D11 Capture ----------------------
22:52:34: DXGI: Found D3D 11
22:52:34: setting up d3d11 data
22:52:34: found dxgi format (dx11) of: 28, size: {1280, 720}, multisampled: false
22:52:34: DoD3D11Hook: success
22:52:34: successfully capturing d3d11 frames via GPU
22:52:38: stop requested, terminating d3d11 capture
22:52:38: ---------------------- Cleared D3D11 Capture ----------------------
22:53:39: ---------------------- Cleared D3D11 Capture ----------------------
22:53:40: DXGI: Found D3D 11
22:53:40: setting up d3d11 data
22:53:40: ---------------------- Cleared D3D11 Capture ----------------------
22:53:40: found dxgi format (dx11) of: 28, size: {1920, 1200}, multisampled: false
22:53:53: ---------------------- Cleared D3D11 Capture ----------------------
22:53:53: DXGI: Found D3D 11
22:53:53: setting up d3d11 data
22:53:53: found dxgi format (dx11) of: 28, size: {1280, 720}, multisampled: false
22:54:01: ---------------------- Cleared D3D11 Capture ----------------------
22:54:01: DXGI: Found D3D 11
22:54:01: setting up d3d11 data
22:54:01: found dxgi format (dx11) of: 28, size: {1920, 1200}, multisampled: false
