SmikeyKanji
Specs:
EVGA GTX 1070 SC in SLI
Intel i5-7600K CPU 3.8GHz (doesn't improve recording at 4.2GHz)
32GB Corsair RAM (2666 clocked speeds XMP)
Asus STRIX z270-F motherboard
3TB WD hard drive space
I tried every setting on YouTube (all seen to be the same) and my own settings but the gameplay seems to be smooth while obs output and preview is stuck at 25 or less. I don't understand. I did a clean uninstall including the settings in my appdata folders and no progress. HELP PLEASE. I just want to record in 60 fps. I even used V-sync and turned my refresh rate from 144hz to 60hz and the issue doesn't change. I changed the game from fullscreen to window and that drops the FPS in the game and/or OBS or both.
  • 2019-02-18 15-15-21.txt
  • 2019-02-18 15-20-48.txt
  • 2019-02-18 15-49-13.txt
  • 2019-02-18 16-06-31.txt
