Question / Help Game running at 60 fps but OBS not capturing 60 FPS
artoflec
Hello
I'm having an issue where OBS preview is showing my video capture device (Avermedia lite gl310 capturing a regular PS4) running at 30 FPS or a framerate lower than 60 fps when it should be capturing at 60 fps. The GL310 can at least capture 60 FPS at 720p which is what my settings are at in OBS.
I'm using NVENC encoding and my PC specs are:
Windows 7 Home Premium 64 Bit
i5-4690 3.50 ghz
8gb ram
GTX 970 4 GB
I am streaming at a bitrate of 3500 with canvas and output resolution set to 720p on OBS Studio 64 bit v 24.0.3
I have my PS4 hooked up to my primary monitor and have OBS up on a 2nd monitor. The game im playing is running 60 fps but the preview in obs and therefore the stream (or a local recording) are seeing it at 30 fps. When using the RE Central capturing software that comes with the avermedia, I was able to capture a video of the game running at 60 fps. When recording from OBS, the video file said 60 FPS but was clearly running at 30. Additionally, when i opened OBS, RE Central was no longer able to capture my PS4 and instead tried to display a glitchy fragment of my monitor. It continued to have this issue even after OBS closed. I'm not sure if the Avermedia Stream engine, OBS, or the capture card are the problem.
I'm not sure if the attached log files are the correct ones so I included the earlier timestamp one from the stream today and the latest one, I did some local recordings so they might be from that, but either way the same issue persists during a stream or during a local recording.
I have tried setting the properties of the video capture device to custom (it defaults to 60 fps anyway) but it didn't alter the preview nor the local recordings or stream.
I hope I included all the necessary information. Thank you for your time.
Last Log Files
  • 2019-12-11 23-15-09.txt
  • 2019-12-11 20-21-32.txt
Narcogen
It looks to me like OBS is saying your capture device is misconfigured or failing:
20:22:37.288: [DShow Device: 'Aver'] settings updated:
20:22:37.288: video device: AVerMedia C835 Capture
20:22:37.288: video path: \\?\usb#vid_07ca&pid_c835#202231300207#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a}
20:22:37.288: resolution: 720x480
20:22:37.288: fps: 59.94 (interval: 166833)
20:22:37.288: format: H264
20:22:37.288: using video device audio: yes
20:22:37.288: sample rate: 48000
20:22:37.288: channels: 2
20:22:37.288: audio type: Capture
20:22:37.655: error: out of range intra chroma pred mode
20:22:37.655: error: error while decoding MB 60 1
20:22:37.694: error: P sub_mb_type 18 out of range at 16 2
20:22:37.694: error: error while decoding MB 16 2
20:22:37.723: error: P sub_mb_type 13 out of range at 15 1
20:22:37.723: error: error while decoding MB 15 1
20:22:37.752: error: mb_type 93 in P slice too large at 66 2
20:22:37.752: error: error while decoding MB 66 2
20:22:37.785: error: out of range intra chroma pred mode
20:22:37.785: error: error while decoding MB 8 1
20:22:37.817: error: P sub_mb_type 4 out of range at 30 1
20:22:37.817: error: error while decoding MB 30 1
20:22:37.851: error: mb_type 39 in P slice too large at 62 1
20:22:37.851: error: error while decoding MB 62 1
20:22:37.885: error: mb_type 121 in P slice too large at 3 1
20:22:37.885: error: error while decoding MB 3 1
20:22:37.919: error: mb_type 103 in P slice too large at 39 1
20:22:37.919: error: error while decoding MB 39 1
20:22:37.952: error: mb_type 4079 in P slice too large at 57 4
20:22:37.952: error: error while decoding MB 57 4
20:22:37.987: error: P sub_mb_type 6 out of range at 37 1
20:22:37.987: error: error while decoding MB 37 1
20:22:38.017: error: mb_type 26 in P slice too large at 19 1
20:22:38.017: error: error while decoding MB 19 1
20:22:38.052: error: out of range intra chroma pred mode
20:22:38.052: error: error while decoding MB 45 1
20:22:38.085: error: P sub_mb_type 6 out of range at 60 1
20:22:38.085: error: error while decoding MB 60 1
20:22:38.119: error: mb_type 38 in P slice too large at 28 1
20:22:38.119: error: error while decoding MB 28 1
20:22:38.155: error: mb_type 32 in P slice too large at 77 5
20:22:38.155: error: error while decoding MB 77 5
20:22:38.186: error: mb_type 113 in P slice too large at 7 1
20:22:38.186: error: error while decoding MB 7 1
20:22:38.220: error: out of range intra chroma pred mode
20:22:38.220: error: error while decoding MB 60 1
20:22:38.265: error: mb_type 38 in P slice too large at 1 1
20:22:38.265: error: error while decoding MB 1 1
20:22:38.301: error: out of range intra chroma pred mode
20:22:38.301: error: error while decoding MB 30 1
20:22:38.333: error: negative number of zero coeffs at 68 2
20:22:38.333: error: error while decoding MB 68 2
20:22:38.366: error: mb_type 70 in P slice too large at 4 1
20:22:38.366: error: error while decoding MB 4 1
20:22:38.395: error: P sub_mb_type 25 out of range at 52 3
20:22:38.395: error: error while decoding MB 52 3
20:22:38.428: error: cbp too large (51) at 24 1
20:22:38.428: error: error while decoding MB 24 1
20:22:38.463: error: mb_type 56 in P slice too large at 17 1
20:22:38.463: error: error while decoding MB 17 1
20:22:38.496: error: negative number of zero coeffs at 33 2
20:22:38.496: error: error while decoding MB 33 2
20:22:38.524: error: mb_type 180 in P slice too large at 30 1
20:22:38.524: error: error while decoding MB 30 1
20:22:38.564: error: mb_type 33 in P slice too large at 4 1
20:22:38.564: error: error while decoding MB 4 1
Narcogen
I don't know, but that log shows that same device failing even at 480p60. What happens if you try 720p30? Basically for any HD capture you want USB3 anyway.
artoflec
Okay so setting my PS4 output to 720p fixed my issue. The preveiw and stream now run at 60 fps. It seems like adding my capture card to OBS, and NOT the Avermedia Stream Engine, meant it was grabbing the native 1080 60 signal from the PS4 - therefore my capture card was downscaling it to 30 fps regardless of my settings.
This can be marked as solved or answered now. I'm not sure why the log showed my card having so many issues but ill add it here anyway just to see how it looks.
And thanks Narcogen!
  • 2019-12-12 17-23-22.txt
