Gnome Wayland Context menus escape OBS Window and Screen
spcified
GNOME Shell 42.3.1
Might be a Gnome Issue.
Behavior:
Menus such as the add sources menu leave the OBS window and the screen making it impossible to select items with the mouse. As seen in screenshot on the bottom.
Expected Behavior:
Menu is always displayed inside the boundaries of the display.
Tuna
Feels like a bug in Qt on Wayland and multiple monitors. Disable all other displays than the primary one and it should be much more reliable.
spcified
Good point.
Tested disconnecting all other displays like suggested, problem still remains.
Might also be related to QT will open also an Issue there.
