Question / Help GPU Not Being Fully Utilised
PizzaPeter1998
Hi there,
When streaming the quality of my streams are hit and miss and I am wandering why. I've recently bought a new GPU so I decided to dedicate my old GPU to encoding the stream however, I have found out that when I start streaming the quality of the stream doesn't seem to be that great and looking at my GPU usage its only peaking at 27% and not fully utilizing it. Does anybody know why? and if so is there a solution around this on how to allow OBS to use the GPU to its full advantage?
Also when recording using the dedicated GPU I have no problems what so ever and the quality is crisp and clear.
Main Output Settings:
NVENC H.264 (NEW)
CQP 7
Keyframe Interval 2
Preset Max Quality
Profile High
  • 2019-10-03 03-23-55.txt
R1CH
Because that's all it needs to use? I'm sure if you increase the resolution or FPS it will use more resources.
